![]() Join Date: Apr 2007
A number of members expressed interested in duplicating my cutouts setup and I had to tell them that one of the electric motors appeared to have failed so I drove home with one open. Thought it was a failed motor as that did happen once, repaired under warranty. Those interested said they wanted follow up on the diagnosis so here it is: Turned out to be a false alarm. After taking the open one off I bench-tested it and it operated normally. Conclusion: the small power connector plug near one motor must have come apart so one didn't work. Put them back on and connected the plugs and they seem fine now. From now on I will check the plugs first if one stops. If there are any other issues I will post it on the forum, but I still like the set up a lot.--Bob
Bob:
I think you have the best Cutout design I ever saw on a C4, and I am surprised more guys have not copied your stealthy setup. Just curious who makes your Cutouts? U.S. made brand or overseas? |
#3 | |
The cutouts are made by Quicktime Performance (QTP) and are sold through Summit Racing among others. Marc generally buys them through Summit. Don't know if some of all of the parts are made in the US. -Bob
![]() Join Date: Jan 2015
Pretty cool.
Are they limited to two positions (open or closed)? Or will they allow partially open settings? For instance, can you open them 10%? |
#5 | |
The cutouts are infinitely variable. I have a momentary rocker switch hidden under the carpet on the passenger side of the console within easy reach. For the track I have them open, for long trips and coming into my subdivision I have them closed so it is just a stock exhaust. Most of the time I like a little rumble so I run with them about1/4 to 1/3 open. --Bob
![]() Join Date: May 2011
Bob your QTP cutouts are on the inlet of the mufflers correct?
QTP use to have a programmable proportional control as well as a remote control. |
#7 | |
Yes my cutouts are next to the mufflers on the inlet side. There are a couple of pictures of them in my albums section. I do know that QTP offers a remote control--I believe Dennis F has one. If I did it again I might get one. I had used the approach of a rocker switch under the carpet before, so I went that route. (In the early 70s living in Boston I had a 67 Corvette Coupe with a hidden fuel cutoff rocker switch in the same position under the carpet. One night it was stolen but we found it a couple of blocks away. Cops wouldn't even file a report; they said of the hundreds of Corvettes stolen in Boston each year, mine was the only one that was ever recovered.) --Bob
![]() Join Date: May 2010
Thanks for all the updates and info Bob. I am really considering your setup and going the stealth route. I'm also on the fence with the Corsa system and their black tip option. I made the mistake of not hearing your system in person while at BG a few weeks ago. I'm not sure of the total cost to do the stealthy system you have with labor and parts here in this area.
I have some considerations with showing the car as well as tracking it. Entering the black 95 in a few weeks to a car show in stock class. When they say stock, they mean stock so putting the factory A molds on and I can't even have AM exhaust. Then at Laguna Seca for example you can't run pass the tower at over 90db or they throw you off the track so there goes the Corsa or you have to let off at that area going up the hill. Decisions, decisions.........Thanks again! ![]()
Craig "ZR-1 NO KA 'OI" "ZR-1 ICHIBAN" 1995 #228 Black/Black with Dunn Heads ZR-1 owner since September 2003 ZR-1 Net Registry Founding Member #0074 NCM Lifetime Member #2048 ![]() |
#9 | |
![]() Join Date: Dec 2005
#10 | |
No problem at Laguna Seca with my setup--it is stock sounding when closed (although maybe a little bit louder with SW headers and no cats, but not 90 db at a distance). If you are at a track that doesn't impose sound restrictions, like NCM, you can open up the cutouts. It is also stock looking unless the judges get under the car and see the cutouts ahead of the mufflers. I always enter my car in stock classes at local shows and still get trophies. No one has noticed the missing secondary pump and tank or the coolant bypass in the engine compartment or the cutouts. If they complain they don't have to judge me. Of course if you already have an aftermarket system and don't have the stock one, you will need to get a stock 95 system which can be hard to find. Anyway it is a fun setup that gives me control on sound. --Bob
