![]() Join Date: Nov 2014
Anyone buy a new sec actuator solenoid from Jerrys and have to modify it to fit? What is involved? A step by step would be much appreciated as i have to pull the plenum and replace this part but could not find an original.
![]() Join Date: Feb 2011
GM has used that vacuum solenoid in a few different applications so most likely only the mounting bracket is a little different.
The mounting bracket is different. It`s easy to change. Just bend the tabs with some pliers and replace the bracket with yours. Duralast is the brand and EVS 34 is the part number.
