Old 05-09-2015   #1
SteveCanyon
Default Hailbeck Chip Help
I sent Marc an email, but being the weekend I may not hear from him. I just installed his chip in my 90. Car starts, runs for a few seconds and then dies accompanied by the service engine light (code 22). Does this over and over and will not continue running. I triple checked all of the connections, etc. Any ideas?
Edit, guess my car has gremlins. Put factory chip back in, car ran fine, put Hailbeck back in, and then ran fine.
SteveCanyon is offline   Reply With Quote
Old 05-09-2015   #2
Default Re: Hailbeck Chip Help
You did not get the chip fully installed......car does not have gremlins....just the chip/ECM if you do not treat it right
Old 05-09-2015   #3
Franke
Steve, I've seen this before just like Dyno says the chip wasn't fully seated. You should be good to go now.
Old 05-09-2015   #4
SteveCanyon
Well, I thought it was seated, would not go down any further. No worries, second times a charm I guess.
Old 05-09-2015   #5
PhillipsLT5
PhillipsLT5's Avatar
Really fixin this 1 up, great
Old 05-09-2015   #6
The blue and white clips on the side must snap into place. Then check the chip by turning ignition to ON, check to see that SES light flashes once.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
