Old 04-29-2015   #1
Torchred96
Default Reduced TO $1500 LT5 Short Block and heads ...Had Rod knock
Reduced!! Hey guys, I need to get this out of my garage. It's the short block that came out of my 91 with 135k miles when it developed the rod knock. I also have the heads that have been taken off. . I don't see any damage in the cylinders but have not explored the bottom end for the knock. The oil pan and pcv cover in the valley is included but there is no oil pump or water pump as i used everything else in the new motor.
I also have the heads that were on it. I will sell separately, but Im looking to get about 1500 or so for everything..obviously negotiable. The heads have had the SPTV's removed and capped and they are not ported. The cam covers are powder coated silver (ish) and have barely a scratch.
Let me know if you have interest . I have to move these out of my shop..too much clutter. write me at sirlancair at yahoo dot com or call or test 305 794 two four zero two.
thanks sam
Torchred96 is offline   Reply With Quote
Old 05-01-2015   #2
Torchred96
Default Re: LT5 Short Block and heads ...Had Rod knock
Reduced to 1500 obo for both heads and the shortbock.. I have to get these out of my way. The cams are included and in good shape. shape...knock didn't affect the cylinders or heads. By top end inspection.I am including the cams!!
Old 05-02-2015   #3
NVMYRC51
Hey Sam I am just up the road in Kendall. I would like to come down and take a look at what you have just for curiosity sake if you have the time.
Craig,
NVMYRC51 is offline   Reply With Quote
Old 05-02-2015   #4
Torchred96
Craig...Anytime after sunday. I work 24 hrs so I'll be home after around 10am monday and tues..even after hours as I'm usually up to midnight..so time is not a problem. give me a call. 305 794 two four zero two when you want to come. Im in Keys Gate North. You'll have to call ahead so I can let the gate guys know. thanks, sam
Old 05-03-2015   #5
Torchred96
Ill keep these up here until the next day or so when I put them back on the auction site separately. Thought I'd give it a try here first.
