Old 04-05-2015   #1
Top Toy
Top Toy's Avatar
Default B&B Fusion Mufflers & Cat Eliminators F/S
I have a set of polished stainless steel B&B Fusion dual mode mufflers, quad oval double wall polished tips (higher quality than standard B&B tips), complete with vacuum valves, vacuum solenoid, wireless receiver, two key fobs, hoses, and wiring. Valves can be opened/closed inside or outside car. Quieter than most with valves closed. Louder than standard B&B with valves open. Straight thru design on valved side for minimum back pressure/max HP. 3" inlet pipes slip fit onto standard B&B exhaust or can be adapted to others. Removed mufflers due to internal vibration at slow speeds. Cut back seam of one muffler in attempt to find/repair vibration but stopped when it became apparent more cutting/welding would be needed. Will be a great set for someone with access to TIG welding. Near new condition except for cut seam. Originally about $1000. Now $300 + shipping.
Also have pair of cat eliminator pipes for '93 to '95. Polished stainless steel but some road tarnish. Custom fabricated by Marc Haibeck. Will add about 5 HP compared to cats. Slight increase in sound level. Originally $500. Now $200.
Email me at dennisderr@cinci.rr.com if interested and I'll send pics.
'95 ZR-1, aqua/gray, #167
368 LPE/Haibeck, Web cams, Stainless Works headers, B&B Fusion exhaust, 18" Fikse wheels, Alcon brakes, lowered. 491 SAE RWHP.
Top Toy is offline   Reply With Quote
Old 04-06-2015   #2
Top Toy
Top Toy's Avatar
Default Re: B&B Fusion Mufflers & Cat Eliminators F/S
Mufflers are sold! But the cat eliminators are still available.
Dennis
Old 05-07-2015   #3
HAWAIIZR-1's Avatar
Dennis
Sending email.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
