![]() Join Date: Jan 2015
I just installed a set of C6 Z06 on my 92 ZR1. The rear tires are much taller and now I'm getting service ASR and service ASB. Are the taller tires the reason or is it something else?
![]() Join Date: Feb 2011
Possibly... assuming that you did not increase the diameter of the fronts in the same proportion.
Mine does not and I am using same wheels w 285/18F an 325/19R tires. My rear tires are about an inch taller than stock.
![]() Join Date: Aug 2013
Almost 6% revs/mile difference may be a problem for ASR.
Diameter Front = 25.6 Rear = 27.1 Difference = +5.9 Width Front = 10.83 Rear = 13.58 Difference = +25.4% Sidewall Front = 3.79 Rear = 4.07 Difference = +7.4% Circumference Front = 80.3 Rear = 85.2 Difference = +6.1% Revs/Mile Front = 788.9 Rear = 743.2 Difference = -5.8% |
#8 | |
#9 |
![]() Join Date: Apr 2007
The constant difference between front and rear wheel speed is to much (more than 4.5%) which triggers the ABS and ASR systems check lights.
I had the same problem after changing to my Fikse wheels with staggered tire sizes 285/35R18 fronts 345/30R19 rears. Solved the problem by machining a set of 50 tooth count ABS reluctor rings for the rear spindles which compensated for the diffence in wheel speed the ABS and ASR systems see. Now life is good again.
Phil Wasinger 1994 Torch Red ZR-1 WAZOO Member George Braml Intake Last edited by Jagdpanzer; 03-17-2015 at 11:26 PM. |
#10 |
