The question of how much faith we should have in our press in crankshaft cup plugs has been bugging me for awhile. I looked around but could not find any engineering information on the mechanical properties of cup plug pressure holding capabilities so I conducted the following pressure test to find out.
Here is the test fixture I turned out on the lathe from 4140 chrome molly steel material to use with the hydraulic shop press: ![]() A 22mm tall sidewall cup plug supplied by Jerry's Gaskets pressed in the 22mm bore of the test fixture with Loctite 620 applied according to FSM instructions: ![]() Set up on the shop press and pumped up to 300 psi test pressure: ![]() Jerry's plug laughed at 300 psi for two hours so I switched to a 1000 psi pressure gauge and pumped it up to the to the full 1000 psi. Amazingly it still held!!. ![]() ![]() Loctite 620 is some tough stuff. Take a look at force it took to press the plug out afterwards: ![]() Conclusion: Anyone using Jerry's 22mm tall wall cup plugs properly installed can be fully confident those plugs are in to stay. Up next is the Dorman 555-119 cup plug which cross references over to the GM 10067639 OEM plug
![]() Join Date: Mar 2007
Awesome research!
![]() Join Date: Dec 2003
Most impressive! Excellent engineering Phil. Very ingenious device to conduct the test.
Nice work excellent execution
David Hertrick |
![]() Join Date: May 2007
Good work Jerry!
Jim |
![]() Join Date: Feb 2009
Great test Phil! I know I will sleep better at night.
Rich
![]() Join Date: Jun 2005
I don't understand what prompted this research?
Has there been instances of the crank plugs "blowing" out?
#9 | |
Rich
1990 Bright Red Coupe #608 380 Stroker, Ported Heads/Intake/Housings/TB Haibeck Secondary Delete Chip / Pete's Cams George Braml Intake / FIC Injectors Coated SW Headers / Corsa Bill Boudreau B/B ZF6 / Viper 4.10 gears Ron Davis Radiator Pioneer AVIC-Z140BH NAV Fikse FM5's 285 / 335 / C6 Brakes WAZOO Member Last edited by Scrrem; 03-16-2015 at 01:09 PM. |
#10 | |
Prompted by Screm's experience and Phil Wasinger's involvement in Screm's engine build, Phil undertook a comparative analysis test between 3 different plugs, the 22mm plug I sourced from the UK, the OEM GM plug and a Dorman SAE size plug. All three of those plugs differed in wall thickness, cup diameter & cup height. The objective being confirmation of the 22mm plug, especially since the GM plug is NLA. Phil's work confirmed the 22mm plug suitability for the intended application. I hope this sheds some light on the importance of the test results.
