Old 11-28-2006   #1
Belsy
Belsy's Avatar
Unhappy new member needs help
Recently purchased my first ZR-1 (90 black w/ red int.) after several other Vettes over the years and need some advice on dash and DIC buttons.
With paperclip I am getting C 13 & H 13 code from CCM but cannot clear because my DIC buttons do not work at all. All fuses look good. No other codes but need help as to should I pull dash apart or??
Also my cluster numbers for mileage seem to be fading as like an old LED watch, is there any one fixing these as I have seen this before on 90 and newer clusters.
Thanks in advance for any suggestions,
Gene
Belsy is offline   Reply With Quote
Old 11-28-2006   #2
jonszr1
jonszr1's Avatar
Default Re: new member needs help
Geno, welcome, PM jeffvette he knows about these things tell himyour a newbe.
Old 11-28-2006   #3
Jeffvette
Gene, the buttons on the DIC units will typically go bad. Most of the time, they just fall out. I imagine there is a problem with the circuit board and if you are handy, you could probably fix it. Otherwise keep your eyes open for a used one on eBay. Gm might still have them. The other option is to contact Jason @ Vette2Vette salvage yard. 815.673.6200
Old 11-28-2006   #4
jonszr1
jonszr1's Avatar
just wanted to say THANX for all you do here jeff you have helped me many times. guys like you keep our dream cars alive. Brad=D>
Old 11-28-2006   #5
Z Factor
Z Factor's Avatar
Thumbs up Re: new member needs help
Hello Gene and welcome to the forum.
Another resource you might check is Arts Corvettes
http://www.artscorvetteparts.com/
Let us know how things progress.
Old 11-29-2006   #6
Belsy
Belsy's Avatar
Thank you, I pulled dash apart and got lucky as connector had come loose behind buttons! My real concern now is the fading center cluster numbers any help or repair suggestions??
