![]() Join Date: Jul 2013
I have a 1990 with Vin number 2396 and it has plastic emblems that the NCRS Manual says belong on a 1991. The car only has less than 5000 miles so I am wondering if the book is wrong or they were changed for some unknown reason. Also, I understand that the 1990 emblems which look different are made out of metal and were held on with nuts and washers mine have no fasteners just adhesive applied.
Would some of you guys check out your cars and advise as to what yours have?? Thanks Dave |
![]() Join Date: Nov 2011
I have 1990 #1786. I'll check tonight when I get home. Pretty sure they are bolted on, at least the gas door one, 'cause I have to wash around it.
![]() Join Date: Apr 2004
I know the gas door has nuts and adhesive, the gas door on both my 91 & 93 are metal. The hood both have nuts on the 91 is metal not sure on the 93. I'm sure the 91 is original as I've had it since it had 9K miles.
Steve 1990 Steel Blue/Black #2355 1990 Red/Red #1473 1991 Quasar /Black #118 Sold 1991 Turquoise/Black #766 Parted Out 1993 Yellow/White #179 Sold 1990 Black/Gray #1361 Headers/4:10s Sold Last edited by We Gone; 02-06-2015 at 10:28 AM. |
Most the new OEM replacements are plastic posts with aluminum chase nuts. My 91 original emblems were ALL metal with metal threaded posts, adhesive and metal nuts. The NCRS book is correct for 90 as they were different than the 91-96 C4 run but incorrect on the 91s they were indeed all metal from the emblem to the threaded posts to the metal nuts. Yours are oem aftermarket replacements
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 02-06-2015 at 11:43 AM. |
![]() Join Date: Aug 2010
Dave: Both front & rear are bolt -on plastic as per my one owner 1990 #1389.
![]() Join Date: Feb 2014
Just happened to see this on eBay. Should help answer your questions AND give you a reasonably-priced option if you need a new one (on the gas door emblem, at least). Good luck.
http://www.ebay.com/itm/NOS-1984-199...f290b3&vxp=mtr |
![]() Join Date: Sep 2013
The 1990 has metal emblems on the front and rear.
The flag colors ere changed in 91. The rear emblem on the gas door according to the manual is suppose to have acorn nut's for < 2000 vin. My 90 is 1964 and it has nuts with integrated washer's. I feel confident the nut's with washer's are correct as my emblems are originals. Atleast that what my last flight judging has proven. 99.3% |
#8 | |
Notice the round circle, the nos part below has a flat and a radius down each side of the large black circle. Last edited by Z06scentair; 02-06-2015 at 04:54 PM. |
#9 |
Gas door
#10 | |
That said, you're the one with the Top Flight, so I defer to you! |
