Old 02-05-2015   #1
Default Where does this bolt go
There are three of them.........and I have lost my mind
Old 02-05-2015   #2
Default Re: Where does this bolt go
Targa Top
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 02-05-2015   #3
Throttle Quadrant to the Throttle Body
Old 02-06-2015   #4
Jagdpanzer
Jagdpanzer's Avatar
I'm with Dom, targa top
Jerry, if you have them, I'm looking for 2 of the throttle quadrant bolts that you mentioned
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 02-06-2015   #5
Yep, you guys are correct. Same style, different size. I've only removed to adjust the new tinted & solid tops purchased 13 years ago. I completely overlooked the bolt length clearly visible in the picture.
I'll have to scrounge around to see Phil. I've seen a couple somewhere, but never cataloged them. I actually have a lot of parts to do, cranks, 5 or 6 blocks, about 20 cylinder heads, dozens of cams, about 25 sets of take out rods/pistons & sleeves.
Old 02-06-2015   #6
Hoarder
But.......Your Hoarding is a lot more organized than mine and ten times as much which is good for all of us
Targa Top
Yep .....thanks ...that is the Targa bolt as I removed one to check.....I just cannot figure out how I ended up with six of those bolts on the shelf
Old 02-06-2015   #7
Hoarder
Maybe..... but you're catching up and adding Dynomite's Rebuilt LT5 Engines to your inventory on a regular basis!
Old 02-06-2015   #8
Hoarder
Yep...that is the Targa bolt as I removed one to check.....I just cannot figure out how I ended up with six of those bolts on the shelf
Must be ALL those multiple C4s Cliff
