01-07-2015 | #1 |
Kissimmee Auction
01-07-2015 | #2 |
Re: Kissimmee Auction
Let's hope they hit the pre-auction estimate!
A rising tide raises all boats. |
01-07-2015 | #3 |
01-08-2015 | #4 |
I will be there as a registered bidder. there are at least 8 zr1's hitting the auction block. last time I was there I let a 1990 black couple zr1 slip through my grasps at 13.5k. I did not see it in the waiting lines and when it hit the block I had not checked it out so I could not bid. best deal of the deal. 50k miles in very nice condition. 13.5k. that was the year of all the callaway zr1's went on the block along with the sledgehammer corvette. Hopefully I will pick up something.
ed ramos #3028
EDRAM454 1990 #3028..siamese ported plen/hous/SGC/fidanza/DRM LTHeaders/DRM roll cage/camber rod/drilled slot rotors hawk track pads/grand sport calipers/full corsa exhaust/Hurst/NO cats/custom SGC chip/cbeamplate/315's on all 4/intake water plugged/smog removed..RC injectors/LED lights..SHOULD NOT HAVE PUT ALL THE MONEY IN IT.. SOLD. |
01-08-2015 | #5 |
I'd like to have that Challenge Car. Seeing Brett's and Mark's cars last year at BG kind of planted a seed that's been germinating.
01-08-2015 | #6 |
01-08-2015 | #7 |
Except for the boats on the bottom.
01-08-2015 | #8 |
