Old 12-31-2014   #1
Default Porting 93-95 Injector Housing
Wrapping up a set of Inj Housing this weekend....
$700 w/exchange
This includes Porting your plenum
Old 12-31-2014   #2
Blue Flame Restorations
Default Re: Porting 93-95 Injector Housing
Great deal for someone!
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 12-31-2014   #3
Pic with 35mm foosball
Old 01-02-2015   #4
Billy Mild
Will these work on the early motors? Do you port plenums as well?
Old 01-02-2015   #5
Plenum Porting is included in the $700..I have a set of early models ready to go also, including the plenum
Old 01-04-2015   #6
Here is stock
Old 01-04-2015   #7
Stock-Top vs ported
Old 01-04-2015   #8
although the 93-95s have bosses on all ports....you can create flow around the boss to help compensate for not being able to completely remove from the primary
Old 01-26-2015   #9
Bump
Old 02-20-2015   #10
Johnny5
Question...I have to change my injectors and I just ordered them and the necessary gaskets. Do you need any extra gaskets when getting a port job from lee? I was thinking of getting this done before I change the injectors since the plenum will be off and would like to do it at the same time. And does it run fine without the marc heibeck chip/tune because my car is all stock so this would be the 1st modification. (1991 Z 27k miles)
Johnny5 is offline   Reply With Quote
