Old 12-29-2014   #1
Scrrem
Scrrem's Avatar
Default Stock Dampener
Over the holiday I took a closer look at the stock dampener on my old motor and it appears that it was getting real close to seperating or has already. I will have to pull it off and check the back side. Glad I am going with the ATI on the new motor. Does anyone have some "After" pics of their grinding work on the front cover/water pump to fit the ATI dampener?
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 12-29-2014   #2
Jagdpanzer
Jagdpanzer's Avatar
Default Re: Stock Dampener
Rich,
Here are some photos I posted up a while back
http://www.zr1.net/forum/showthread.php?t=12428
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 12-29-2014   #3
Scrrem
Scrrem's Avatar
Awesome Phil! I knew you posted, just couldn't seem to find them.
Thanks!!
Rich
Ron Davis Radiator
