Go Back   ZR-1 Net Registry Forums > Club Regional Areas > Mid-Atlantic Region
Old 12-08-2014   #1
Scrrem
Scrrem's Avatar
Default Mount Vernon Maintenance Day - December 13th
There will be a MVMD in Mount Vernon, VA on December 13th, 2014.
We will be pulling the motor on Rich's 1990 ZR-1. If you haven't seen a motor pull on a ZR-1 yet, this is you opportunity. It shouldn't be a long day, most of the major work is done, just need to get the lift in and snatch it out. I can also give you a peek at the new motor
Lift won't be available but can do other off-lift tasks.
When: Official start time is 9:00 AM. Come when you can stay as long as you like.
If you have any questions contact me at 703-304-9467
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 12-12-2014   #2
QB93Z
QB93Z's Avatar
Default Re: Mount Vernon Maintenance Day - December 13th
I am not going to make it to the MVMD. (Business obligations).
Have fun and take some pictures.
Old 12-12-2014   #3
nelson007
nelson007's Avatar
Wish I could, never seen a C4 engine pulled.
Just got back from Chicago.
Nelson
WAZOO MEMBER
1993 #124 Ruby
1994 #??? Red/Black
1995 #061 Black/Red
2012 ZR1 Preproduction
nelson007 is offline   Reply With Quote
Old 12-15-2014   #4
Scrrem
Scrrem's Avatar
Well, stock motor came out without any issues, thanks to all that came out. Now to clean up the engine compartment, get ready for the new....
Rich
File Type: jpg 1948194_10204302516180415_9022448603171907396_n.jpg (31.7 KB, 90 views)
Ron Davis Radiator
