Old 12-06-2014   #1
Scrrem
Scrrem's Avatar
Default Power Steering Pump
Those of you that have done motor pulls, do you disconnect and remove the power steering pump or just leave it connected and moved to the side?
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 12-06-2014   #2
Jagdpanzer
Jagdpanzer's Avatar
Default Re: Power Steering Pump
Rich,
I removed it with the engine so I could give it a thurough inspection and cleaning. Then filled it with fresh fluid after reinstalling the engine.
Be sure to use a proper tubing wrench when disconnecting the pressure line to the power steering unit.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 12-06-2014   #3
Scrrem
Scrrem's Avatar
Thanks Phil!!
Rich
Ron Davis Radiator
Old 12-06-2014   #4
Rich
The AC Compressor and Power Steering Pump lines are left connected when I pull LT5 engines. The AC Compressor and Power Steering Pump are then set aside with the hoses connected being careful not to put too much pressure on the AC solid lines connected to the AC Dryer.
Also............I installed LT5s with SW Headers attached. Makes it very easy to install the Header Bolts.
Dynomite is online now   Reply With Quote
