Old 11-21-2014   #1
Default Tip of the hat to Tony Davilla on cutouts
I owe Tony Davilla a tip of the hat for the inspiration to relocate my cutouts. I had Marc Haibeck’s standard installation which eliminated my spare tire carrier. But I like keeping my spare with me and I like keeping the car’s appearance fairly stock. After seeing pictures of Tony’s manual cutouts right up against the muffler I decided to investigate putting my electric ones there. Needed to make sure there was enough clearance space there for the motor and the turndowns that I like. I dummied up a wooden and PVC pipe mockup of the cutouts and sure enough there was enough room. So when WARP TEN was at Marc’s for an oil change this week I had him relocate them and reinstall the tire carrier. Looks great and they work just the same as before. So if anyone is thinking of cutouts but is hesitating because they want to keep the spare tire carrier, this is the way to do it. Here are some pictures:
Old setup:
Relocated:
Old 11-21-2014   #2
mike100
Default Re: Tip of the hat to Tony Davilla on cutouts
Nice job. At first I thought that will be loud, but the cats and resonator should do a good job of simply making the exhaust note more authoritative. Sort of like muffler eliminator kits with an on/off switch.
I'm starting to wonder what would sound like if I had internally pipe-modded my stock mufflers instead of my SW units.
Old 11-21-2014   #3
Hi Mike--
I have headers, no cats and a stock 95 exhaust system with the resonator and mufflers. When I want it quiet it is stock quiet (maybe a little louder without cats; great for long trips). When I am, say, drag racing or just want to scare small animals and set off car alarms, I open the cutouts and it sounds like straight pipes--which it is. Very loud. I run normally with the cutouts about one third open and close them when I come into our subdivision so my wife doesn't complain. Some would say it is not a smooth mellow sound but I like it and especially like the ability to be quiet when I want. And of course with the stock system there is no drone from resonance.--Bob
Old 11-22-2014   #4
Tony Davila
Tony Davila's Avatar
WARP 10,
That looks good and thanks for the credit, yeah I didn't want to give up my spare tire also due to I like driving to BG. I'll be up at BG next year with my Z if anyone wants to check out my system.
I will most likely do the same mod to my Grand Sport because it is super loud all the time. No substitute for the quietness of the factory mufflers. I will use electric cutouts on my GS.
Tony Davila is offline   Reply With Quote
Old 11-22-2014   #5
ZR1North
You've done it again, Bob - and thanks to Tony as well. I am delivering my car to Marc this week for winter overhaul (510 pkg with Corsa and SW headers). I was hesitating on cutouts for same reason as you guys. I like this fix.
ZR1North is offline   Reply With Quote
Old 11-24-2014   #6
Originally Posted by Tony Davila View Post
WARP 10,
You might consider my hidden rocker switch vs the standard QTP toggle, as described in a nearby post. It is now easily accessible. I found the toggle switch supplied with the cutouts to be very stiff to use and when Marc first installed it, it was in a position I could not reach easily below the hush panel near my right knee. --Bob
Old 11-24-2014   #7
Tony Davila
I like where you put the switch, that is very neat. Good job!
