Took my car to have it detailed and specifically told them not to pressure wash the engine, they did anyways. Now it has a misfire in it under power, at idle its fine. The miss isn't constant its intermittent. Any ideas on where to start? Its a 91, and there are no check engine lights on.
coil packs, injectors, vac leak, either way sounds like they need to pony up for some parts.
![]() Join Date: Feb 2011
pull the spark plug boots to see if there's water in the spark plug holes- that might be all it is.
#4 | |
Inspect each spark plug hole for moisture as mike100 suggests. Leave the plug boots out of the holes for a few hours to dry out just in case.
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 11-06-2014 at 09:04 PM. |
What Cliff posted above
![]() Join Date: May 2011
If you have a wet dry vac try to suck out as much of the water as you can. Than change the port to exhaust and blow out the area's under the plenum where you can get the nozzle in the openings.
If you have access to a blow gun and a compressor blow out as much water as you can. Additionally take some small caps and fill them half way up with salt and strategically place them in the engine compartment to absorb the moisture. |
![]() Join Date: Sep 2006
most any Cabellas and even k mart sells dehumidifying kits,used in gun safes etc. much better then salt/as Robert says get as much out the easy way/blowing etc. 1st/I also use a halogen or heat light/
![]() Join Date: Jul 2004
park it and let it dry.
I have sprayed my motor to clean it before but I also let it sit for a while afterwards.
