Old 10-20-2014   #1
Z06scentair
Z06scentair's Avatar
Default Front shock bushing needed
In need of one or two front shock bushings. This is the bushing that is on the top of each shock under the steel washer.
Brad
Z06scentair is offline   Reply With Quote
Old 10-20-2014   #2
Default Re: Front shock bushing needed
Contact DRM that's were I picked up my pair. GC
Old 10-20-2014   #3
Z06scentair
GC
Just checked and those appear to be poly bushings, I was hoping to find a set of original take offs if possible.
Old 10-20-2014   #4
Originally Posted by Z06scentair View Post
GC
Got it yep I upgraded to all poly. Sorry about that. GC
Old 10-20-2014   #5
Z06scentair
No need for apologies....I appreciate the reference!
Do you still have the one's removed?
Old 10-20-2014   #6
phrogs
phrogs's Avatar
The smaller round ones? I have some
JOHNNY P
Currently own
Old 10-21-2014   #7
WVZR-1
Brad
Eckler's actually still show the upper for FX3 on the front. They mention poly also and don't reference it to the GM OE # 10157964 but ...... poly used as a reference or is it actually a "premium" product? I would think poly desired and I'd maybe consider a used OE for a "one time" National NCRS event only maybe. I don't believe I'd be wanting to R&R the adjusters frequently.
Old 10-21-2014   #8
Z06scentair
Johnny
I would guess 1.5 to 2" in diameter with a .4375" center bore. It appears to be .4375" thick.
Brad
Old 10-21-2014   #9
Z06scentair
Dave,
Thought about that last night, it does worry me a bit about changing them out again for a show.
For some reason one side seems to swell and push out from underneath the steel washer. It seems some of the fluid has leaked from that shock and caused this swelling. Poly would be much less prone to the swelling as the original EPDM bushing.
Old 10-24-2014   #10
phrogs
phrogs's Avatar
These are what I have used originals.
I don't even know which is which right now, been a while since I have messed with the shocks.
JOHNNY P
Currently own
