10-09-2014 | #1 |
Oil pan bolts
I know this has been discussed numerous times in the past. My question is to tighten all the oil pan bolts what has to be removed?
Jim 1990 Z # 2441 1959 c-1 230 HP 4 speed frost blue/silver 3 owner 2011 cts-v 556 HP, manual 6 speed 1955 chev 2dr ht PP 265 3 speed w/OD |
10-09-2014 | #2 |
Re: Oil pan bolts
You should be able to remove the two beams that attach to the rails and from cross member. The engine and mounts are actually sitting on a thick plate(cradle)....so the beam are not supporting the engine; the plate along with the transmisson beams will support the motor w/o the beams....
10-09-2014 | #3 |
Re: Oil pan bolts
My second question is concerning the two inch diameter oil spot that appears under the front of the engine, passenger side, every time I park the car. Could this oil be from the cooler lines? Car is stock 67,000 mi. Not driven hard.
10-09-2014 | #4 |
Re: Oil pan bolts
Oil cooler lines or one of the 2 oil pressure sensors......
10-09-2014 | #5 |
Re: Oil pan bolts
Thank you!! You are a wealth of knowledge. I want to get this taken care of before my four day drive to the gathering in May. Can't wait to make the trip!
10-09-2014 | #6 |
Re: Oil pan bolts
I will post some pics this weekend of the cross members/oil sensors
10-09-2014 | #7 |
Re: Oil pan bolts
Since I have you on line. If the cooler lines are the culprit are they available locally like a dealer? If the oil sensors are bad, where I get them?
10-09-2014 | #8 | ||
Re: Oil pan bolts
Oil Filter Adapter Functions Jerry's Gaskets has the Sensors and Switches in stock. Quote:
Jerry's Gaskets Also has New Oil Cooler Hose Assemblies in SS Braid or Black Braid. ZR1 Engine (LT5) Bolts and Hydraulics
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 10-10-2014 at 03:27 AM. |
10-10-2014 | #9 |
Re: Oil pan bolts
Thanks. I will order from jerry! Is this a relatively easy job?
10-10-2014 | #10 |
Re: Oil pan bolts
To help you find the items Lee defined as possible oil leak source.
You have 2 styles of hoses to choose from, black-braided and SS braided BLACK http://jerrysgaskets.com/store2/root...roducts_id=888 Stainless http://jerrysgaskets.com/store2/root...roducts_id=887 The two oil pressure units (1 is a switch, the other is a sender) Lee referred to Switch http://jerrysgaskets.com/store2/root...roducts_id=346 Sender (Big one on top) http://jerrysgaskets.com/store2/root...roducts_id=106
