Old 10-09-2014   #1
Default Rebuilding calipers,need some part numbers.
I know this has been covered here before but cant seem to find it.Im ready to put my calipers together and would like to use AC Delco parts for the seals.Does anybody know the correct part numbers for the front-rear seals for these?Thanks.
Old 10-09-2014   #2
WVZR-1
Default Re: Rebuilding calipers,need some part numbers.
GM 10112655 would have been a package for the rear. You might try to have someone change that to a package. NAPA? The only people I've seen with the package is Dorman-First Stop D352746. The rear package does Camaro, Firebird and Fiero also.
The fronts are a 10104486 and these as well as the rears are NLA. Dorman-First Stop might have them also D352004.
For the fronts you can check with a Ford dealer also, the fronts would be likely '94 - '98 Mustang.
ACD #'s would have been 10112655 > 173-512, 10104486 > 173-511
