Old 10-04-2014   #1
Mystic ZR-1
Mystic ZR-1's Avatar
Default Powdercoat
Tentative Winter project, powdercoat plenum and cam covers etc.
With a good masking job, can the TB be powdercoated without removing
the throttle blades etc? I don't want to mess with the screws that hold
the plates to the shaft if possible. If it can be done, what about the oven's heat
effecting the "coating" (what it's called escapes me at the moment...) used to
make the seal on the throttle plates. Any soft parts to be concerned about?
Old 10-04-2014   #2
Default Re: Powdercoat
There are a few plastic parts in the TB, would not do it....DAG can be replaced
Old 10-07-2014   #3
Daniel_Mc
Daniel_Mc's Avatar
Lee is correct. I did our LT5 in PC a few years ago; you will need to fully disassemble the TB to have it coated. It is not a big deal at all.
-Daniel
Daniel_Mc is offline   Reply With Quote
Old 10-07-2014   #4
TB screws are a PITA ....the screws are deformed at the bottom so you have to cut off the ends.....might be other ways. I wonder if maybe heating them might work...not sure if they were crushed or if they were soldered...
Old 10-07-2014   #5
Daniel_Mc
Daniel_Mc's Avatar
I used a dremel to cut the melted ends off then just redrilled the holes and taped for new screws. But I had a TIME with those on CJ's Z for some reason.
-Daniel
Old 10-07-2014   #6
I did the same, did not need to tap the second set...used red threadlocker
