09-09-2014 | #1 |
Can’t reset ride control codes
Driving around Bowling Green with the NCM anniversary, my Service Ride Control light came on. I was just cruising on the freeway and said “darn.” The next day, also just cruising steady on the freeway, the light went off. I love it when things fix themselves J
When I got home, I jumpered pins A and C on the ALDL to see what ride control codes were stored. I got every code! What? Mind you, the light isn’t on, so I guess this must be “history” or something. I disconnected the battery and still had the same result – all codes. I followed the reset procedure in the FSM (ground pin C for two seconds and repeat the process a total of three times), and still had the same result – all codes. This is the same issue rogerzr1 had here http://www.zr1.net/forum/showthread....t+ride+control there’s no resolution listed in the thread L Any ideas? Gary
1990 ZR-1 #2180 Red/Black Many of the usual mods for 460HP, tuned by Marc Haibeck ZR-1 Net Registry Member #1548 |
09-09-2014 | #2 | |
Re: Can’t reset ride control codes
When the SRC light comes on again then pull the codes. It should not be ALL the codes. Did you change the shocks recently?
09-10-2014 | #3 | |
09-10-2014 | #4 | ||
09-10-2014 | #5 |
Selective Ride Control Solution TIPS
The FX3 shock actuator deterioration can cause all sorts of intermittent problems FX3 Selective Rid Control TIPS
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 09-10-2014 at 02:14 PM. |
