Old 08-31-2014   #1
Roadster
Roadster's Avatar
Default Can the LT5 experts fill me in on.....
Ok, I think I have an idea why, but am not really sure, so can the LT5 experts who have the knowledge and understanding of this engine explain the following to me....
Why is it that if you let the Z sit for a week or even two weeks before you start the engine, that there is not any chain rattle upon first start-up???
I understand why there is chain rattle during some restarts, and that there is a kit available (which I have) that once installed, eliminates that problem or almost completely eliminates the problem.
We had the Z out today, and first start-up, no noise, most restarts after that the dreaded chain rattle.....
Just trying to learn more about the system......thanks for any info........
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 08-31-2014   #2
Default Re: Can the LT5 experts fill me in on.....
No expert here but it sounds like you have a good check valve in your oil filter.
I have no chain rattle on my 91 or 93 even if they set many weeks. Both have Blue GM filters.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 08-31-2014   #3
Roadster
Roadster's Avatar
That would seem to be true, but its on the restarts that it appears the check valve isn't working as it should, only that it appears to work better when the engine is cold as opposed to when the engine has been running and is hot!!!???
I also have a Blue GM filter. Hopefully over the winter I will attempt to install the kit for this, just have to see what the time factor allows me to do....as there is always something going on........
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 09-01-2014   #4
Jim Nolan
Mine went away years ago after my second synthetic oil change. I use the blue PF970.
Old 09-01-2014   #5
Kevin
Kevin's Avatar
chain rattle is annoying but not harmful. I don't even notice it anymore
Old 09-01-2014   #6
Karl
Karl's Avatar
I barely notice it and that is only if the car sits for a long time. Also the car starts quicker (or at least seems to) if I turn on the ignition first wait about 3 seconds then start.
1993 ZR-1 #211 Yellow On Beige Beast #2
1992 ZR-1 #427 Black On Black *Sold*
1985 L98 Blue On Blue *Sold*
Old 09-01-2014   #7
Roadster
Roadster's Avatar
I hear you on that. ...if mine sits for day or longer no rattle on startup. ...as mentioned earlier, its just those hot or warm restarts that bug me.....I am using Mobil 1 , might switch to Amsoil next time around and hopefully get that kit installed
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 09-02-2014   #8
spork2367
I've been using the white "Napa Gold" filters that are made by Wix and they have a great anti drain back valve. Zero rattle.
Old 09-02-2014   #9
secondchance
Originally Posted by Roadster View Post
I hear you on that. ...if mine sits for day or longer no rattle on startup. ...as mentioned earlier, its just those hot or warm restarts that bug me.....I am using Mobil , might switch to Amsoil next time around and hopefully get that kit
I am not a mechanical engineer so my guess may be wrong. Having said that, from what you are saying, it seems, when oil is fully warmed up and engine start is initiated oil draining out of hydraulic tensioner is faster then the oil system pressure build up to feed the tensioner. Whereas, when the oil is cold (perhaps due to higher viscosity) oil is being held in the hydraulic tensioner longer and pressure build up is seemless.
I noticed that if I turn the key without starting 2-3 times (did it to intentionally to move the pulleys a bit) when I actually start chain rattle was severe which never happens on daily normal start. I concluded that when I ran the motor w/o starting oil in the tensiners were being drained and w/o actually running were not replenished w/ system pressure. Just my theory.
secondchance is online now   Reply With Quote
Old 09-02-2014   #10
Roadster
Roadster's Avatar
I also have a Mobil 1 filter, along with the Bosch oil filter to use in the future, but just might try the Napa Gold, like you have....
Either am I, but what you are saying makes sense to me. I have to go out soon and will take the Z to run my errands. Will report back later. The Z has sat for 2 days, so we shall see!!!
1974 LS4 454 Vert
1974 L-82 355 Vert.
