08-31-2014 | #1 |
My latest mod!!!
Still learning about the LT5, so I decided to add this item to avoid the possible collapse of the air duct during high rpm operation, I purchased this part. Although we have specific vendors that carry parts for our vehicles, and I have supported them recently, with that being said, I found this part on the "bay".
Had a good write-up and some of you may have already purchased this or know of it. Took a good 20 minutes to get it installed, and it feels and looks like it will work very well. No way anything is going to collapse with this installed. BTW, I never told you guys that I own multiple, yes multiple ZR1's and also another ZR-1 (a 95), only thing is they are attached to the wall......
Tom 1994 ZR-1 #009 "captured test fleet car" 1974 LS4 454 Vert 1974 L-82 355 Vert. 1982 L83 CFI...now a retired "dd"....Sold WAZOO Member Last edited by Roadster; 08-31-2014 at 12:36 AM. |
08-31-2014 | #2 |
Re: My latest mod!!!
I use one of those also. Bitch to install.
08-31-2014 | #3 |
Yes it was, but got it done......so you used to??? was it on the ZR-1 that you sold?
08-31-2014 | #4 |
Link please??
08-31-2014 | #5 | |
Sort of wonder if the thickness of the phenolic reduces amount of airflow vs. The aluminum. On the other hand, the phenolic is smoother with fewer protrusions into the airflow (ie. rivets and seam).
08-31-2014 | #6 |
Another option, hoops from Marc
08-31-2014 | #7 |
Geeze... I thought you were saying you got it for your 458. As in Italia 458! Then I realized you were talking of your Black Rose beauty!
08-31-2014 | #8 |
no problem I will send you a PM with the info.......
08-31-2014 | #9 | |
Very happy with the mod, glad I did it........ Yes, saw that, but I liked the insert better, you do have to undo the air assembly for easy install of the air duct, but no biggie, and priced the same. Marc, has great products, his chip is fantastic......
09-01-2014 | #10 |
good mod. I did it months ago. Not to hard to install and my air bridge is solid. this thing will never collapse.
