Old 08-24-2014   #1
Racinfan83
Default Console Bezel Color??
I have a small chip off the edge of the ashtray cover I would like to touch up. Does anybody know what touchup paint color will match the color of the cover/bezel on a '90?
Old 08-24-2014   #2
Default Re: Console Bezel Color??
This may be as close as you get.
http://www.mamotorworks.com/Corvette...-gray-601395-1
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 08-25-2014   #3
Racinfan83
Thanks!
Old 08-25-2014   #4
yes that is what I am using
Old 08-25-2014   #5
KILLSHOTS
How well does it match the factory paint? Are you able to paint just one piece and have it match up perfectly with everything else?
Old 08-25-2014   #6
it is close in the picture I posted.. top bezel is worn and not redone.. bottom is redone
in this picture the ashtray/cup holder door is not redone
Old 08-25-2014   #7
nelson007
nelson007's Avatar
Hello Jeft,
How did you prep console before you applied the paint?
Thanks,
Nelson007
QUOTE=-=Jeff=-;210461]yes that is what I am using
[/QUOTE]
WAZOO MEMBER
1993 #124 Ruby
1994 #??? Red/Black
1995 #061 Black/Red
2012 ZR1 Preproduction
nelson007 is offline   Reply With Quote
Old 08-25-2014   #8
Only one panel got primer, then other was cleaned with soap & water
I did a lot of custom cutting and merging on these panels. I found the primer helped keep the coating even
I have 2 doors I am finishing and I primed those as well...
Old 08-25-2014   #9
nelson007
nelson007's Avatar
Thanks Jeff
QUOTE=-=Jeff=-;210468]Only one panel got primer, then other was cleaned with soap & water
I have 2 doors I am finishing and I primed those as well...[/QUOTE]
WAZOO MEMBER
1993 #124 Ruby
1994 #??? Red/Black
1995 #061 Black/Red
Old 08-26-2014   #10
Racinfan83
Jeff - do you think I could spray this in a small cup to get just enough on a tiny brush to fix the chip? If you look at the pic closely you can see the chip on the drivers side of the ashtray cover about 1/3 of the way up from the bottom...
