Well....same ole same ole
![]() I am rebuilding the Top End on #3032 the Last 1990 ZR-1 sold to public (57K miles). Everything removed/restored/replaced on Top End (Plenum, Secondary Vacuum system, HVAC Vacuum, Plugs, Coils, Starter, Crank Case Vent Cover, Alternator, AC Compressor (not disconnected). This is my standard Top End Restoration. This time I will leave the Water Pump as there are NO leaks at all and ALL bolts were tight. 1. Replaced Power Steering Pulley with Billet Aluminum Pulley. 2. Replaced Belt Tensioner Pulley with Billet Aluminum Pulley. 3. Replaced Crank Case Vent Cover Gasket (several loose bolts - use Red Loctite). 4. Replaced Aftermarket Spark Plug Wires with LT5 Original Plug Wires. 5. Blocked TB Coolant at Injector Housing (appearance is as stock). 6. TB Coolant Return Line to Coolant Surge Tank Blocked. 7. New Spark Plugs. 8. New Secondary Port Throttle Linkages. 9. New RC Injectors (SL4-205s). 10. New Primary and Secondary Injector "O" rings. 11. New Plenum Gasket (use NO gasket sealant of any kind as there is NO Coolant.....Dry Gasket- NO Loctite). 12. New Crank Case PCV "L" hoses under Plenum. 12. Reconditioned Vacuum Canisters (shined up). 13. Reconditioned Starter Solenoid (wire brush contacts on plunger). 14. This time I had to replace bearing on Solenoid end of starter armature (it was a bit rough). 15. New Radiator Hoses with rounded edge clamps. 16. Checked all Coils for proper and consistent resistance. 17. Reconditioned Coil Plate (shined up). 18. Checked Alternator Bearings and shined up Alternator. 19. Replaced Fuel Line "O" Rings at Connection Rear Passenger Side of Plenum. 20. Replaced Injector Housing Coolant Manifold Gaskets and bolts (Use Heat to remove original Torx bolts). 21. Checked ALL Injector Housing Bolts for tightness (Did NOT remove Injector Housings as there were NO oil leaks). 22. Used light Steel Wool (0000) and Simple Green on Plenum and Cam Covers (Will leave Stock Look without Painting or Powder Coating). 23. Removed cover (six 4mm Torx 20 bolts) and dried out TB Coolant Area above TB. Will Replace this cover with Carter Billet Aluminum (ZR-1). 24. More when I think of it ![]() ![]() NOTES: Everything Degreased and HOT WATER Pressure Washed when TOP END Disasssembled. This included clearing the Valley Vent through Bell Housing. Oh....LT5 ran great (I thought) but found four bad Injectors (resistance 10 ohms, 10 ohms, 6 ohms, 6 ohms) Compression checked earlier and ALL Cylinders 215 lbs within 5 lbs. ALL Fluids were Replaced (Engine Oil, Transmission Oil, Differential Oil, Coolant) and Differential Drain Plug Installed Earlier. Haibeck Chip and Starter Relay were also installed earlier. Typically I check and locate ALL vacuum leaks on secondary system but this LT5 had NO Vacuum Leaks (Secondary Canisters functioned perfectly BEFORE Start of Top End Restoration). ![]() ![]() ![]()
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 08-18-2014 at 04:06 AM. |
![]() Join Date: Dec 2003
Sweet!! You are a passionately OCD documenter. Must be the engineer in you.
#4 | |
![]() TB coolant is now blocked but you cannot tell by looking ![]() All new RC SL4-205 injectors and some other stuff ![]() Fired it up and it ran perfectly ......even with TB Coolant BLOCKED ![]()
That is why I now will call him the
"Detailed Dyno Documenter" Or "Triple D" for short ![]() |
![]() Which by the looks of it....NO ONE can tell TB Coolant Blocked at Injector Housing. And.......those hoses for TB Coolant are brand new WITHOUT Clamps (why have clamps when there is NO Coolant Pressure). Those RC SL4-205 Injectors run sooooo smooth ![]() Again...this three day Top End included one day for disassembly and repair/restoration of parts, one day for thinking, and one day for re-assembly (including a test drive up to 120 mph). ![]() ![]() ![]() Note: The Nice RC Injectors Red Stencil on corner of rear lift top glass.
Hey good job and way to go DDD.
Or should it be 3XD or D3X or TriD |
![]() ![]() Need to borrow my camera and tripod there Cliff? |
#9 | |
I like Triple D ![]() Triple D sounds like something to do with Corvette Babes which is ALL good ![]() Thanks for all you do and especially like what you have in your signature ![]()
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 08-18-2014 at 04:20 AM. |
#10 |
"Triple D sounds like something to do with Corvette Babes which is ALL good"
Like the Triple Dipper? http://www.urbandictionary.com/defin...riple%20Dipper OH wrong link - I meant the Triple D available from you local Walmart No doubt the Vette Babes would like this very much http://www.walmart.com/ip/Crock-Pot-...Black/21154908 Last edited by WB9MCW; 08-18-2014 at 10:27 AM. |
