Old 06-03-2014   #1
icarus-54
icarus-54's Avatar
Default shifter
What's the trick to getting the top boot out to put in a hurst shifter? Is there some other way than lowering the back of the trans?
icarus-54 is offline   Reply With Quote
Old 06-04-2014   #2
Default Re: shifter
You may want to consider this shifter for the ZR-1
http://www.zfdoc.com/S6-40ShifterOptions.htm
Old 06-04-2014   #3
QB93Z
QB93Z's Avatar
Default Re: shifter
If you are asking about the leather boot, you have to remove the center console lid, then remove the shifter bezel (2 screws at the rear corners and 1 screw under the front cup holder). Remove the shifter knob. The leather boot is attached to the bezel. Then there are 4 screws to remove the rubber boot. Be careful, there is a lot of sticky sealant around the rubber boot lower edge. Don't get the sealant on you interior.
Under the car you have to pull back the rubber boot to access the pin that allows the shifter link to be disconnected.
It isn't possible to lower the back of the transmission without removing the C-Beam, which is a much bigger job than doing the shifter.
Good luck.
Old 06-04-2014   #4
icarus-54
icarus-54's Avatar
Default Re: shifter
I removed everything down to the rubber boot, it appears to be under the floor and try as I may I couldn't get the top rubber boot out without fear of ripping it. I have all the instructions for the Hurst and things went well till I tried to remove the boot.
Old 06-04-2014   #5
QB93Z
QB93Z's Avatar
Default Re: shifter
The rubber boot is tucked around a lip on the tunnel. You have to get a corner or edge on the right side peeled up and then work your way around the perimeter. Once again, be careful with the sealant under the boot. It makes a mess on carpet.
Reinstalling the boot is also a challenge because it is hard to tuck under the left side of the boot because of the limited clearance to the interior trim.
Good luck
Old 06-04-2014   #6
icarus-54
icarus-54's Avatar
Default Re: shifter
Jim, thanks oh so much, I'll give it a whirl
Jack
Old 06-04-2014   #7
Default Re: shifter
I hope your Hurst has a reverse lock out feature.
Old 06-05-2014   #8
icarus-54
icarus-54's Avatar
Default Re: shifter
IS the hurst shifter dropping into reverse a common problem?
Old 06-05-2014   #9
Default Re: shifter
No but with no lock out safety is would be expensive if it ever did happen by accident.
A few years back another member was entertaining the same deal to put a Hearst shifter in. If I remember right it had no special lockout for reverse and it is possible to make the mistake and wreck the tranny so he elected not to go that route.
Old 06-05-2014   #10
QB93Z
QB93Z's Avatar
Default Re: shifter
I have never had a problem with reverse on three ZR-1's with Hurst shifters.
