Old 05-21-2014   #1
Schrade
Default In-frame welded nut gone...
What are the options here?
Lag screw? Open a keyhole saw access hole in the side, to hold a nut? (the latter has little appeal, for more reasons than just one).
In theory, a perfectly round hole doesn't weaken the material, but in practice, well ... practice and theory sometimes don't go one hand in the other...
Ideas here?
Old 05-21-2014   #2
Default Re: In-frame welded nut gone...
See if you can find a nutsert that will fit the hole. Many options.
http://avdelusallc.com/products/nutsert.shtml
https://www.google.com/#q=nutsert
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 05-21-2014   #3
Schrade
Nut insert would probably work there Steve, but the reeding might not get THIS job done...
I'm already on it here. Y'all gettin' ready to see some brains in action (and never mind who I'm borrowin' the brains from ).
Old 05-21-2014   #4
Schrade
Wire...
30 lb fishing line
Old 05-21-2014   #5
Schrade
Oh yeah - you squared out the hole, with a 3-sided file / rasp. Never mind that it's not square - THAT works out even better, as you'll see below here.
...to put in a carriage bolt:
...before you pulled it through
Then get a nut on it, and run the nut down to lock the square into the [out-of-perfect] square hole.
Old 05-21-2014   #6
Franke
American ingenuity at work.
Old 05-21-2014   #7
Now that's a very inventive fix.
Steve
1990 Red/Red #1473
