Old 05-09-2014   #1
Route 66
Route 66's Avatar
Default 93 ZR1.????
I have a 93 ZR1 It Has 17,000 miles on it. My question is when I hit a bump something in the rear of the car makes a sound like a loose shock or wore out shock. [ A loud thump ] I have checked for anything that might be loose. Found nothing. Put new oem type shocks on it. It is still doing it. Has anyone had that type of problem. If so what was causing it ? Your help would be greatly appreciated...............Thanks Ellis....................
Route 66 is offline   Reply With Quote
Old 05-09-2014   #2
Default Re: 93 ZR1.????
Rear spring cushions? Lose caliper?
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 05-09-2014   #3
Route 66
Route 66's Avatar
Thanks for your thoughts. The spring rubber looks like it might be a possibility. Do you or might someone know where I can get new rubbers for the rear leaf spring...........Thanks Ellis...........
Old 05-09-2014   #4
http://www.parts123.com/parts123/yb....Z5Z5Z50000050F~~~
Steve
1990 Red/Red #1473
Old 05-09-2014   #5
nelson007
nelson007's Avatar
Spare Tire loose.
Nelson007
WAZOO MEMBER
1993 #124 Ruby
1994 #??? Red/Black
1995 #061 Black/Red
2012 ZR1 Preproduction
nelson007 is offline   Reply With Quote
Old 05-09-2014   #6
Route 66
Route 66's Avatar
We Gone and Nelson007 thank you.. / I will look in to that tomorrow.
Old 05-09-2014   #7
Check your spare tire/hanger. Mine was loose and made a sound like that onece!
Old 05-09-2014   #8
Route 66
Route 66's Avatar
Thank you..
Old 05-09-2014   #9
When you get it figured out...let us know what it was
Old 05-10-2014   #10
Route 66
Route 66's Avatar
I will post it here. It might be a few days I will have to order the spring rubbers. ....Ellis
