Old 05-04-2014   #1
Vetman
Vetman's Avatar
Talking Exhaust sound
Borla exhaust has been on my z since I have owned it. I love the sound, especially as rpm pass 2000 to 2500 under light acceleration. Anytime a car is along side me drivers usually take notice when I run through that rpm range. My question is does stock exhaust and after market exhaust have the same or similar menacing sound at that rpm range?
1990 Z # 2441
1959 c-1 230 HP 4 speed frost blue/silver 3 owner
2011 cts-v 556 HP, manual 6 speed
1955 chev 2dr ht PP 265 3 speed w/OD
Vetman is offline   Reply With Quote
Old 05-04-2014   #2
msorenso
msorenso's Avatar
Default Re: Exhaust sound
Just installed a Corsa, no cats, SW headers and it sounds very healthy plus NO DRONE!!!!
msorenso is offline   Reply With Quote
Old 05-05-2014   #3
Fully Vetted
Fully Vetted's Avatar
I have the SW's and no cats. Just need to install my corsa's. What catback are you running?
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 05-05-2014   #4
tf95ZR1
tf95ZR1's Avatar
I have a Borla exhaust and also love the sound.
The problem is the resonator REALLY robs you
of HP. I replaced the resonator with an X-pipe
(and headers) and WOW! Yep, resonance
around 1800 rpm but for me that's OK.
Old 05-05-2014   #5
KILLSHOTS
Stock exhaust makes NO noise whatsoever; far too quiet for these cars, in my opinion. Even a stock exhaust with the resonator removed makes virtually no noise. The aftermarket systems all sound different but all add sound over stock.
Old 05-05-2014   #6
Jim Nolan
Smile Re: Exhaust sound
SW's, no cats and Corsa. Sounds good to me.
Old 05-05-2014   #7
Racinfan83
I just installed a Borla catback on mine. It makes a "tinny wraaaa" noise at about 3k rpm. As opposed to the normal "low rumble". Worse when cold, and really short. As in a space of maybe 200-300 rpm. Never hear it otherwise and once it warms up it is lessened.
Is that the noise you are talking about? #wonderingifIcanfixit
Old 05-07-2014   #8
batchman
That sounds like a hardware rattle to me, from here anyway. Our car is a Borla with mix of piping (headers, no resonator, kludged cats) but there's nothing tinny about it, inside or out of the car. Does have quite the drone at times from idle to 2400 or so. Of course I've only heard it from outside the car a couple times.
Cheers,
- Jeff
Old 05-07-2014   #9
KILLSHOTS
Yep, "tinny wraaaa" sounds like a loose heat shield to me. I've had problems with those on both of my Vettes. It will generally only occur at a very narrow and specific RPM range.
Old 05-07-2014   #10
Racinfan83
Don't know what it could be - there are no heat shields on this one. But Yeah that's kinda what it sounds like. Have to see if I can get a vid of it here in a day or two.. I got under the car and retightened all the bolts thinking that might be it after having driven it several miles but that didn't change it a bit. The only thing I can even imagine I might have done different is that I used a new "old" header collector gasket on the passenger side flange since the stock one that was on there was torn up when I took off the stock one. The gasket I had matched the holes so I figured it was good??
