Old 10-11-2006   #1
billfarmer
Default Help, maxed out 144mph
Hello all, I am a lucky guy. I am in the greatest Air Force in the world, own a ZR1 and live in Germany. I do have a problem though. The other day I go for a spin in the ZR1. Sun shining (uncommon here) open road, I am ready to do it. I run 5th up to 5,000 rpm around 130 something (trying to keep my eyes on the road), shift to 6th, I hit 144mph and that was it. It would not go any faster. What tha? Any ideas? The car is supposedly stock, 13K miles. At 100mph the tach is at 2100ish. Help. Thank you
Bill Farmer
95, #007
dark red/beige
billfarmer is offline   Reply With Quote
Old 10-11-2006   #2
ajaxajax2000
ajaxajax2000's Avatar
Default Re: Help, maxed out 144mph
Hi Bill,
Did you turn the "Full power" key?
Peter
PS. The best airforce in the world is the Swedish Air Force. (Not that I want to start a debate on this. Others probably have other thoughts on this)
'92 ZR-1, black on black, mostly stock (sold)
ajaxajax2000 is offline   Reply With Quote
Old 10-11-2006   #3
blackjack
im not sure you will be going much faster in 6th...also,at 5k in 5th,doing 130 mph,youre probably geared 4.10....but i might be wrong
bj
Old 10-11-2006   #4
Fort94z
I would not shift into 6th. Use 5th for your top end run. Also, I agree with Ajax 2000, confirm that your in full power mode.
Fort94z is offline   Reply With Quote
Old 10-12-2006   #5
Z Factor
Z Factor's Avatar
Bill Farmer
95, #007
dark red/beige
Hello Bill, and welcome to the forum.
The greatest Air Force in the world is correct.
Anyone thinking differently would only have to ask how long their Air Force would last against the USAF, and the one that lasted the longest before their final plane was blown out of the sky could claim 2nd place.
As to your top end dilemma, there could be several reasons, not the least of which are some of the suggestions you have already been given. Is you ZR-1 running smoothly at idle and all through the gears? Is the exhaust normal with no smoke or excessive gas smell?
Old 10-12-2006   #6
A stock ZR-1 will go the fastest in 5th gear, 6th is a .5 overdrive and drops the engine revs and power so far the car will actually go faster in 5th.
Tom is offline   Reply With Quote
Old 10-12-2006   #7
40th#381
Not if you have 4:10 or 4:30s
Jan
40th#381 is offline   Reply With Quote
