Old 04-30-2014   #1
LantanaTX
Default Code 14 and low coolant level light related?
I have code 14 and the low coolant level Light on. I have checked connections to sensors and they are good. I am assuming I need a low level sensor for the header tank and a temp sensor (to ECM)?
[SIGPIC][/SIGPIC]1991 #0663
LantanaTX is offline   Reply With Quote
Old 04-30-2014   #2
WVZR-1
Default Re: Code 14 and low coolant level light related?
I know you enjoy acronyms so I'll just do a thread:
http://www.zr1.net/forum/showpost.ph...4&postcount=15
CTS for the ECM is under the plenum. Have you pulled the plenum? Do you have a FSM? 6E-A-36 & 37 and there will be some diagnostic and resistance values in there also.
Old 04-30-2014   #3
gbrtng
gbrtng's Avatar
The sensor in the tank is not replaceable - you replace the whole tank assy.
Used to be about $50 at your local dealer.
Old 04-30-2014   #4
LantanaTX
That is what I was thinking until I finally found a coolant level sensor for sale online. It doesn't screw in?
Old 04-30-2014   #5
LantanaTX
Thanks, I have had the plenum off twice, once for injectors the day I bought it in Denver and again two days latter back in Dallas to replace a coil pack. I am getting pretty at it! less than 20 minutes! I will be taking it off again soon to strip and recoat the plenum, injector housing and cam covers. Just received some Carter bling in the mail today for that job! I will check temp sensor when I take things apart. Yes, I have the FSM. It is in not good shape, missing the first few pages and the last few. Makes looking things up very tough!
Old 04-30-2014   #6
WVZR-1
It is serviced with the tank. It's still available from GM and there's new on eBay also but if you've a relationship with a GM dealer I'd think less expensive locally.
GM # 10157994
Old 04-30-2014   #7
Demps
Demps's Avatar
I have a bunch of stuff you need off a '91.
Ted
Old 04-30-2014   #8
LantanaTX
Ted
Sending PM
