Old 04-25-2014   #1
kablamo
Default Suspension: FX3 over ride?
Drivers side shock needs replacing. Actuators have been disconnected before I purchased. FX3 electronics have been messed with and found spliced wires. I'd rather replace the entire suspension and keep the FX3 disconnected or over ride it. Any suggestions on suspension kits that work with the ZR1? Car mentioned here is a 1991 ZR1.
Thanks so much! Just finished fixing vacuum leak, replaced plugs and wires, and soon injectors. Just wanting to make the suspension work! Thanks!!!
kablamo is offline   Reply With Quote
Old 04-25-2014   #2
Default Re: Suspension: FX3 over ride?
Coil overs DRM are the best
Old 04-25-2014   #3
USAZR1
USAZR1's Avatar
Any suggestions on suspension kits that work with the ZR-1? Car mentioned here is a 1991 ZR-1.
http://www.vansteel.com/index.cfm?fu...&SubGroup=1972
Old 04-26-2014   #4
kablamo
Thanks for the suggestions folks! Just got some Accel injectors ordered, now to tackle the suspension. Can't wait. Pictures to come. You guys on this forum are awesome!
Old 04-26-2014   #5
kablamo
Do the coilovers require modification or are they bolt on? I haven't run into instructions anywhere yet
