Old 04-23-2014   #1
chriskinzel
chriskinzel's Avatar
Default Missing around 5K
My 91 has developed a miss at about 5,000 RPM. I have changed injectors with Accells, new plug wires last fall, new plugs, fuel pressure is in the 40-45 psi range. Secondary's removed with Hailbeck chip. Are my coils going? I think they are original. What else could be causing this problem. TIA
Chris
chriskinzel is offline   Reply With Quote
Old 04-23-2014   #2
LantanaTX
Default Re: Missing around 5K
Chris
I had the same problem. I used a timing light and pointed it at the valve cover to watch the flashing. I moved the timing light conductor from spark plug wire to spark plug wire. I could easily see the miss on two cylinders. This happened to be two cylinders that shared the same coil. Guess what? New coil pack and problem gone!
LantanaTX is offline   Reply With Quote
Old 04-23-2014   #3
Congrats thats awesome!
Old 04-23-2014   #4
Schrade
I got burned by one of my accounts once for $4K (bankruptcy).
(J/k there, CK; hope you get it sorted out there)
Old 04-24-2014   #5
Z06scentair
Z06scentair's Avatar
Z06scentair is offline   Reply With Quote
Old 04-24-2014   #6
LantanaTX
Old 05-09-2014   #7
chriskinzel
Ok, I still have a miss. It comes when I am pushing it hard. Generaly around 5k, but it has come at other RPM's. I have replaced all coils, and plugs. I have a fuel preasue gauge and it never drops below 40 psi. If I stay on it when it stars to miss i get a code 31 (camshaft sensor). Could the camshaft sensor be causing the miss and it only sets a code if I stay on it? Or is the miss causing the sensor to go bonkers because if the erratic RPM's. I am stuck and need some help from 'da brothers'.
Thanks
Chris
Old 05-10-2014   #8
Z06scentair
Thanks
Chris
The camshaft sensor can cause these symtoms, replace that first since it triggers the SES light.
Old 05-10-2014   #9
Kevin
Kevin's Avatar
Ya my zr-1 makes me miss about $5000 too
Old 05-10-2014   #10
chriskinzel
That part ain't cheep, but I think that is what I am going to need to do. Thanks Z06scentair! I am afraid I might me missing more than $5k when this is all done.
