Old 04-18-2014   #1
Roadster
Roadster's Avatar
Default Haibeck chip install...need help.....
Purchased the Haibeck chip for the 94, received it yesterday and went to install today.....some confusion.....BTW, trying to contact Marc, but his regular line is giving me the fax signal.
In his instructions, it shows an adapter module, where the top half of his chip plugs into. I do not have that adapter module. I can install his chip, but all of those pins are exposed, there is nothing to plug them into.
Now my ECM label is worn, so I can't determine any part numbers.
But here is the info on my PROM that is in the ECM:
95 BKKR LT5 Proposed 95 ESC
ESC 0647
93-95 MY
PROD
T. Holand
3.30.94
So can this chip be installed with those pins exposed???
Do I have the wrong ECM in the car, because it doesn't have the adapter module for those pins to plug into???
thanks for any info............Tom
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 04-18-2014   #2
Kevin
Kevin's Avatar
Default Re: Haibeck chip install...need help.....
Tom,
Where in pa are you? I don't have a 95 but on my 90 it's fairly simple, remove 4 or 6 screws holding down the cover with gasket, take that off, there's 2 small clips holding the chip in, pull those back, take the old chip out pop the new one in, replace cover. I'm sure that someone with a 95 will be along to help you out.
Now that I think about it I did the same process with a 94 test ecm I used.
Old 04-18-2014   #3
ESC 0647
93-95 MY
PROD
T. Holand
3.30.94
Pics would help. It sounds like you have a piggy back daughter board
Old 04-18-2014   #4
You need to take the blue cover off. Doesn't fit oitherwise.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 04-18-2014   #5
Roadster
Roadster's Avatar
Thanks for the replies, everything makes sense now......off to work, update tomorrow.......and thanks to Steve (We Gone) for the help on the phone today....all is appreciated..................Tom
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 04-19-2014   #6
tf95ZR1
tf95ZR1's Avatar
Hi Tom!
I have a MY1995.
If you have Marc Haibeck's performance PROM, Kevin is
correct. You straight swap your OEM PROM for your new
PROM.
If its a Haibeck smog PROM, xfirez51 is correct. You have
to piggy back your Haibeck PROM with your original PROM.
Then remove the blue plastic cover on your original PROM
(2 plastic tabs on each side) so the both will fit and maneuver
them inside the window/ECM casing and push it carefully
into the original motherboard slot. The retaining tabs should
flip back into place. Should have come with instructions that
include pictures. Any other questions PM/email me.
Ted
Old 04-19-2014   #7
Kevin
Kevin's Avatar
If tom is near Pittsburgh I'd be happy to stop by and help
Old 04-19-2014   #8
csavaglio
There's instructions on PDF posted on Marc's page too at the end of the paper that describes everything the chip alters.
csavaglio is offline   Reply With Quote
Old 04-20-2014   #9
Roadster
Roadster's Avatar
Figure it out with the help of everyone.....thx to all....
Yes, finally did it that way, I won't even tell you how I got the original chip into the ECM with the blue cover on and hooked up and then taken apart and out of the ECM, then blue cover removed and hooked up the correct way. No I won't tell you at all how I accomplished that maneuver...
Originally Posted by tf95ZR1 View Post
Hi Tom!
I have a MY1995.
PROM.
Ted
Ted, I have a 94, but on my PROM it has 95 references......and thanks for the offer to contact you for additional help........
I also did not know that there was a Performance PROM, along with the Smog PROM, unless the Performance PROM is the custom build unit???
Yes, I did see and have the instructions that you mention, just was brain dead the other day and was not used to plugging a chip into the existing PROM as this one required......
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 04-20-2014   #10
Roadster
Roadster's Avatar
Latest update......chip installation successful........took it out tonight, and runs extremely good. Enjoying the fans coming on at lower temps, did not go above 213 degrees at a standstill, so very happy about that.........just have to drive it more and more and more.......feels very strong......glad I made the change....
1974 LS4 454 Vert
1974 L-82 355 Vert.
