Guys--Is there any other place oil could enter the combustion chamber other than rings,valve seals/stems,PCV system?The car is once again burning oil at an alarming rate to the point where it smokes out the tailpipes at idle pretty good now..It's to the point where it's embarrassing to drive the car..Compression checked out good,PCV system is operating effectively as Plenty of suction is present at the valves, and on both Plenum PCV pipes..Removing the oil cap when running there is no blowby coming out..The car still pulls hard without hesitation..Pulling the plugs with only 300 miles on them show oil on 2 of the passenger side plugs..I've read stories about the header bolt on the passenger side,and also the filters under the cam covers.Are either of these a possibility?My gut is telling me it needs valve seals..If thats the case I will be selling the car for sure..Haibeck wants 9K to rebuild the motor to it's current 368 specs..I know valve seals dont mean a total rebuild but if the motor has to come out then why stop there?I can't justify putting that much coin into it considering it is not a prestine car..Me fixing it myself is out of the question as I don't have the time as of now due to work..Your advice is my last attempt at getting some more suggestions before the car is EBay bound..I love the car but Ive had enough..
![]() Join Date: Jan 2009
Have you tried going to 10w40 or even 15w50?
This ONLY to measure the impact on consumption.
![]() Join Date: Mar 2007
Did we check and make sure the IHs are proper for this car?
Are the A Mold wheels still available?
Is it possible when the car was modified they swapped the wrong IHs and the ones on the car do not have the oil vapor plugs in the IH or the heads are different?
https://jerrysgaskets.com/store2/roo...20Housings.pdf
so how much for the car with the failing LT5?
Lee-I doubt that's the case as the car ran with no noticeable oil consumption or smoke the first few months of me owning it..As far as oil,I'm running Mobil 1 10W40..It's been 10-20* here in NJ for the last 2 months so I didn't want to step up to a 15/50 or 20/50...Again,if I was an expert I wouldn't be here asking for help..But at the rate it's burning with constant visible smoke there is no way I can be convinced that going from a 10 wt to a 15w is going to solve this..There is oil finding its way into the combustion chambers and plugs are chalky Black(rich) with traces of oil on a few of them just after a few hundred miles..The car doesn't misfire or hesitate..It also has plenty of power until plugs foul out a few hundred miles later..This leads me to believe the problem is in the heads,,not the block..I'm sick as I just put $3K in wheels and tires on this thing..Phillip--If the car goes bye bye,I will decide if they will go with the car,or be sold separate..You have my word they are yours if they are sold to anyone..If I can't get to the bottom of this within the next few days I'm gonna clean the car up,type up a brief description,take some pics and it will be for sale..I bought the car to enjoy it and have spent more time monkeying with it..I'm mentally exhausted as of now and I'm really leaning toward getting rid of it..If that's what I decide I will offer it up here first..If there is no interest then it will be Fleabay..
#9 |
Fellas- here is a vid just shot of it running in my driveway..Although the smoke looks like condensation smoke it has a much more Blue tint to it in person..
https://www.youtube.com/watch?v=R2Fh...e_gdata_player https://www.youtube.com/watch?v=XT6O...e_gdata_player Last edited by Mitsumark; 04-07-2014 at 06:29 PM. |
#10 |
![]() ![]() Join Date: Feb 2010
It would be worth the effort to take it to Pete or Marc for a professional evaluation and repair before selling it.
