Old 04-06-2014   #1
Roadster
Roadster's Avatar
Default Some questions on my new ZR-1.....
I have a list of questions, I know there is a wealth of info here, but would like to know what other owners have done or do pertaining to these issues....
1- do you or have you used any fuel additive? I have used and still do, Lucas fuel injector cleaner in the 82, and it works fine, no problems or issues.
2- what tire pressure do you use in the front and rear tires? I have always run 30-31 lbs in whatever tires I have had, so is that the norm for us?
3- have you ever used or mixed Sunoco racing fuel (high octane) with your fuel, like maybe adding a galon every once in awhile?
4- do you run anything less than 93 octane, have you used 92 octane? I have both available.
5- an oil question....do you still use Mobil 1 or have you switched to another brand?
6- how about air filters....what do you use now?
That's all I can think of for now, thanks for any info.....I am enjoying the ride, it feels so good rolling down the road in a ZR-1........
Old 04-06-2014   #2
Racinfan83
Default Re: Some questions on my new ZR-1.....
You will get many different opinions with those questions - but here are mine. From what I understand - any fuel additives are not recommended. If you still have the catylytic converters - you won't want to mix any race gas with the premium either. 92 or 93 should be fine. I use Mobil 1 just like I do in all my other vehicles. I have a. K&N air filter on mine - just because I also have those on all my vehicles. The factory paper filters are pretty good from what I have read though. Google up "ZR-1 Specialist" for Marc Haibecks site - lots of info there. And welcome!
Old 04-06-2014   #3
Just my opinion
Never
32-34 front, 30 32 rear
No, but I would
only 93
Mobil or Amsoil
Stock in 1 K&N in the other
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 04-06-2014   #4
efnfast
Stabilizer at the end of season.
28-29 lbs.
I used to use an octane booster, Marc Hiebeck tells me our engines are not octane limited, so now I carry it in case I can only get 87 octane.
Marc programmed my chip for 91 or better.
I've run Amsoil since I bought it 20,000 mile ago. Don't know what the PO used.
Had a K&N in it when I bought it. I just clean it regularly.
Don't cha just love that car???
Old 04-06-2014   #5
Roadster
Roadster's Avatar
thanks for the opinions so far, and yes I just love that car......
7- have you switched out the factory chip? what have you switched to?
8- have you disconnected the 1-4 shift? I read that if you go above 1500 r's in first it will eliminate the 1 to 4 shift and go into 2nd gear. It appears to do that for me.
9- what brand oil filters are you using?
10- the small (in length) black molding that attaches to the bottom of the windshield on both the LS & RS, what is the best material to re-attach? do you use super glue, or something else?
I also tighten up all of the very small screws from hoses etc., on the passenger side of the engine, some were very loose.
Also been talking to David from MD who has supplied me with alot of info......and good tips.......thanks David
Old 04-06-2014   #6
efnfast
There is a pole about which chip people have. Marc H wins by a long shot.
Marc's chip eliminates this. Gotta be driving like a girl for it to happen anyway. (I'm sure I'll catch some heat for that comment).
AC Delco PF-970-C. Good anti drainback valve.
Under the hood?
Tint the windows if you can get away with it, really makes the car look sinister. - Steve
Old 04-06-2014   #7
Roadster
Roadster's Avatar
Steve, thanks for more tips, yes that molding is under the hood, will have to take a pic......not a big fan of tinting.......to dark for me...lol
11- underhood lights do not come on with the hood open....so I'm assuming that a PO installed a toggle switch, just have to locate it.......
Old 04-06-2014   #8
efnfast
Gordan Killabrew tells me he used to remove them for better under hood ventilation. These should be the same for any C4, so easier to source.
Or he pulled the plugs, my 90 has one on each side in the fender well, not attached to the hood.
Old 04-06-2014   #9
All great ?s
Both to Haibeck.
Marc's prom does it
GM or Bosh
a small amount of trim adhesive.
Most likely the fuse is out, look just over the left side marker. small black fuse holder with cover.
Steve
1990 Red/Red #1473
Old 04-06-2014   #10
Roadster
Roadster's Avatar
will check that out....thanks.....
Originally Posted by We Gone View Post
All great ?s
and all great answers..... appreciate all of the replies.........
