Old 03-29-2014   #1
mgbrv8
Default wideband O2 sensor kit
Is there a wideband O2 sensor kit you all would recommend for our cars
Any and all options are welcome and mentioning draw back of brands on the market are welcome also
Dave
Old 03-29-2014   #2
Schrade
Default Re: wideband O2 sensor kit
I'm interested here on this too...
Do W/B sensors help ECM overcome lean condition at throttle tip-in?
Old 03-29-2014   #3
There are a number of WBO2s available.
I have used the Zeitronix ZT-2 for a number of years. Very reliable. I have a gauge attached which will displays Lambda, AFR, and MAP volts. Also an RPM input and datalogging software.
http://www.zeitronix.com/Products/zt2/zt2.shtml
Dynamic EFI has one that allows you to program stoich for the fuel being used.
http://dynamicefi.com/TT-1.php
No, you need to modify the calibration to do that. The WB is tool to help you in identifying where you may be going lean. From there you can adjust your pump shot otherwise called Acceleration Enrichment (AE) tables.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 03-31-2014   #4
rkreigh
no, they are just for monitoring as the factory ECM only works with the stock narrow band 02 sensors
that being said, the WB 02 will help you log what the A/F ratio is during throttle tip in to see what the car is doing which will help with the tune.
you can also log with a number of products (Ease, diacom, ect...) to a laptop using the stock ALDL data stream and the narrow band sensors will give you an idea of the AF ratio
only problem is with the narrow band sensors they aren't accurate at very rich or lean mixtures (hence the term narrow band)
95 390 LPE ZR1 (505 rwhp)
