Old 03-28-2014   #1
Karl
Karl's Avatar
Default About a tank of gas later my oil catch can....
About a tank of gas later my generic oil catch can has caught the following. Look and you will see the trapped oil. Not bad!
http://postimg.org/gallery/3906ejyc/
1993 ZR-1 #211 Yellow On Beige Beast #2
1992 ZR-1 #427 Black On Black *Sold*
1985 L98 Blue On Blue *Sold*
Old 03-28-2014   #2
scottfab
scottfab's Avatar
Default Re: About a tank of gas later my oil catch can....
Hard to see what the scale is. How much would you say that is?
Teaspoon? Tablespoon?
Scott
Old 03-28-2014   #3
Karl
Karl's Avatar
At least a teaspoon and a half. Oil catch can is from Ebay. $16 & free shipping. Time will tell if it is a good value or not.
This picture shows the best shot. I brought the can inside and as it warmed up the oil began to settle at the bottom.
http://postimg.org/image/cltcd7vpv/
Old 03-29-2014   #4
I would say that is not bad. Just one less teaspoon less oil to cake onto the secondary valves and foul the plugs.
$16??? Dayam!! Do tell (please)... I won't even admit what I paid for the Moroso unit I just bought this past winter at Winner's Circle (in Joliet)...[sigh]. (However, I was told mine would also lick my genitals too, so maybe there's that - it better for what it cost me!!)
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 03-29-2014   #5
Karl
Karl's Avatar
http://m.ebay.com/itm/280788609371?nav=SEARCH
I did use a better quality hose to run the pcv line.
Old 03-29-2014   #6
scottfab
scottfab's Avatar
Originally Posted by pushrod-v8 View Post
What a deal. Just ordered one.
This is one of those mods I've been studying for years.
It's easy to back out and offers a real benefit.
Glad I waited. What a deal !
Thanks for sharing.
Scott
Old 03-29-2014   #7
Karl
Karl's Avatar
Thanks for sharing.
No problem. I mounted mine in front of the ASR assembly and used some simple zip ties to strap it to the hard a/c lines. I also have the clear tube facing the opposite direction of the exhaust. So far so good.
And for the record this is about 3 tanks of gas and not one! I remember getting this unit last summer/fall when it was still hot outside. Needless to say I am satisfied with results and the cost.
Old 03-29-2014   #8
Anyone know what filter to use on this catch can when needing replacement?
I use this catch can and the one issue I ran into w it was a vacuum leak. At the bottom of the glass was a pull valve that would empty out the oil from the bottom. After a while it stuck open creating a small but perceptible vacuum leak.
Another one of those things that I discovered while just looking at stuff and noticing the idle smoother when I closed the valve manually. Now it's JB welded shut.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 03-29-2014   #9
Karl
Karl's Avatar
Dominick, do you use the same catch can as I do? There is no filter in the one I use. It is hollow. I have considered stuffing stainless steel wool in it but I see no reason why. Plus i'm paranoid about the engine sucking in some loose material.
Old 03-29-2014   #10
Franke
PRv8, I bought one without the filter media as well but put a short down tube in the inlet side to force the vapors to travel downward first. then I added stainless steel Brillo pads as a medium for the vapors to travel upward thru the SS pads to the exit port. I believe the pads will capture a little more of the oil as it presents a surface area for the vapors to attach to. I haven't done any driving yet but will soon as the weather is getting better. Good stuff on this forum...
