Old 03-25-2014   #1
564crewdog
Default Spare tire
Is there a trick or a technique to re-attaching the spare tire storage tray under the car? I'm making the assumption is that the threaded portion of the bolt should tighten and loosen (mine is frozen) to stow the tire/jack. Am I missing something?
Thanks!
Rich
564crewdog is offline   Reply With Quote
Old 03-25-2014   #2
efnfast
Default Re: Spare tire
Lug wrench should fit it. If it's frozen, you can get to it to hit with some penetrating oil if you remove the rear license plate.
efnfast is online now   Reply With Quote
Old 03-25-2014   #3
564crewdog
Thanks...I'm going to have to drive it home in the "stow flat tire" position with it hanging down a bit to fix it.
Old 03-25-2014   #4
564crewdog
Thumbs up Re: Spare tire
Thanks again, after a thousand turns on the wrench and some PB Blaster I'm back in business!!
Old 03-25-2014   #5
efnfast
In my garage, not on the road, I use an air gun. It takes a lot of turns.
