Does anyone know approximate available numbers for HP and Torque, with only airflow modifications?
To try to be clear, I'm giving a motor with 2"+ headers, 3" pipes, and max induction porting - Air Horn, TB, Plenum, IH's, and cyl head port inlets. What #'s might be had? And what are the numbers, in millimeters, for each intake component??? And finally, WRT the memory calibration module, is more coding necessary, besides Marc's 2' delete chip? |
![]() Join Date: Apr 2004
I would only give it a guess of 500hp 450tq with a good tune. that about what I have with PnP thru heads 33mm & 63mm TB, headers and Corsa's
#3 | |
WHat are you meaning by 'PnP' thru heads'? Valvework? Plug n Play ![]() Is there that much choke in the intake? |
Just a guess based on what I ended up with, PnP port and polish intake injector housing and heads, yes the valves were done. Cams retimed to 93-95 specs.
#5 | |
This is the Haibech 500 package less the lightweight flywheel. I think a better question is the max hp without going into the cylinder heads or cams? |
![]() Join Date: Mar 2007
Without touching the heads or cams its 400 rwhp give or take 5-10; so if you use .85 as the standard to convert that puts you in the 470-480 at the crank......
I know someone will chime in and say why the ,85 conversion is not correct because parasitic loss only takes up X amount of power....blah blah blah... But I am going with 470-480hp 495-510 with heads........give or take 5-10....
![]() Join Date: Jan 2004
Around 430rwhp with full head porting... maybe 410rwhp with just the tops of the head intake ports massaged.
Robert ZR-1 Net Registry Oregon State Director 91 ZR-1 #431 Black/Black LPE 368 |
