Old 03-20-2014   #1
chriskinzel
chriskinzel's Avatar
Default Oil catch can
I am going to install an oil catch can on my car. I can't seem to find a goof mounting spot on the inside of the fender. Will it work in the open space in front of the wheel? I am questing this because it is quite a run for the hoses.
TIA
Chris
91 ZR-1 Red on Red #922
chriskinzel is offline   Reply With Quote
Old 03-20-2014   #3
chriskinzel
Default Re: Oil catch can
Thanks Dynomite, but the can I have is too wide to fit in that location. Just wondering if it will work a little farther away from the engine.
Chris
Old 03-20-2014   #4
Karl
Karl's Avatar
Look.at this picture and you will see where I mounted mine in front of the asr cover. Ignore the 17C on the plenum :-)
http://postimg.org/image/402swhoib/
1993 ZR-1 #211 Yellow On Beige Beast #2
1992 ZR-1 #427 Black On Black *Sold*
1985 L98 Blue On Blue *Sold*
Old 03-20-2014   #5
Chris
The length of the tube isn't an issue; volume isn't a factor that pipe length, say to the headlight well and back is going to be impede flow significantly. I believe Bob G mounted a substantial can there that he had fabbed up to serve his 427. Al too might have one there as well.
FWIW,
P.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 03-20-2014   #6
Dmod81
Mine is mounted down under the headlight:
Dmod81 is offline   Reply With Quote
Old 03-20-2014   #7
FWIW,
P.
I think BobG. mounts his "substantial can" in the drivers seat most of the time.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 03-20-2014   #8
What you get away with
Old 03-20-2014   #9
chriskinzel
Looks like I'm good to go under the headlight. Thanks all!
Chris
Old 03-20-2014   #10
Schrade
I'm still highly in favor of a 'catch can', but I've seen no one's setup that has any manner of cycling the oil BACK to the CC (or the dirt, or SOMEwhere), with some sort of check valve integrated 'thereinto'......
After a few trips to the grocery store, a full catch can don't catch - CAN it?
