Old 10-02-2006   #1
crazyb1
crazyb1's Avatar
Default U Joints
A clunk and scraping noise during accel from the rear side is a u joint going bad correct? I hope it's not worse. Thanks for your input
Crazy
'90 ZR-1 Red/Red #1239
SGC P/P Plenum/IH, Headers, B & B, Hurst, K & N
"Red RocketShip!"
crazyb1 is offline   Reply With Quote
Old 10-02-2006   #2
jonszr1
jonszr1's Avatar
Default Re: U Joints
Most likely ,one way i found out was crawl under the car grab the 1/2 shaft and see if you can get movement. I did and sure enough they were badhope that helps. ps its an easy fix just follow the shop manual.
Old 10-03-2006   #3
guinnessdood
guinnessdood's Avatar
Crazy
...and make sure you buy the GOOD U-joints! Spicer Life U Joints are the good ones. Definitely not the place to cheap out...
Uly
Past OWNER 90 ZR-1 #0120 Red/Saddle
UT Plate: EZR1DER
guinnessdood is offline   Reply With Quote
Old 10-03-2006   #4
crazyb1
crazyb1's Avatar
Thanks for the input.
"Red RocketShip!"
