Old 03-04-2014   #1
randy ransome
randy ransome's Avatar
Default Shift knob
Anybody have a shift knob for a ZR-1 they want to sell. Mine came with a black T-handle and I like it but you can't have a drink in the cup holder and shift without hitting the handle.
randy ransome is offline   Reply With Quote
Old 03-04-2014   #2
scubasteve
Default Re: Shift knob
any pics? and any interest in a stock knob?
scubasteve is offline   Reply With Quote
Old 03-04-2014   #3
Randy,
C5 shift knobs are identical to C4. So you have a wide choice.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 03-04-2014   #4
csavaglio
And new stock ones are pretty inexpensive even if you add the shift pattern insert into the cost. If you get a C5 one, make sure the pattern is the same....I can't remember if C5s have reverse on the right or left.
I think I have a white ball (Hurst or B&M, maybe?) with the shift pattern on it. It was on one of my C4s when I got it....I replaced it with a new stock one. You're welcome to it, if you want it. Maybe 15 bucks shipped?
Chris
csavaglio is offline   Reply With Quote
Old 03-05-2014   #5
KILLSHOTS
Randy,
XFire,
How do they attach? Just traded an 87 4+3 for my new 90 Z. On that, I popped the overdrive button with a screwdriver, pulled out a metal pin with needle-nose pliers and threaded the knob off. Same procedure? So any C5 knob will fit my 90 ZF shifter?
Thanks for the info!
Chris
Old 03-05-2014   #6
randy ransome
Well I forgot to post my car has a Hurst shifter.
Old age is getting to me.
Old 03-05-2014   #7
csavaglio
There's a metal T shaped block piece holding it in under the shift pattern part. Its a friction fit and takes some effort to get it out. Then it just threads on like any other knob. Most of the aftermarket shifters have the notch for that piece so you can use the stock shifter. Any other shift knob just threads on.
Old 03-05-2014   #8
WVZR-1
Originally Posted by KILLSHOTS View Post
XFire,
Chris
Removal tutorial - I don't use the "wrecking bar" but there's images that are useful. I use a small "knocker" (slide hammer) - dent puller or seal remover after drilling with an appropriate sized drill bit.
http://forums.corvetteforum.com/1574666157-post1.html
Randy,
A bit misleading - the C5 and the C4 share the same 9/16 - 18 thread but that's the end of the similarity. Not everyone is familiar with the difference in the shift patterns. A knob with a shift pattern needs to be for a ZF M6.
Old 03-05-2014   #9
The C5 knob itself is identical to the C4. I have both. They screw on the same and use the same "lock key". The difference is the stitching pattern.
And yes the button for the (C4) ZF has Reverse to the right and down rather than Up.
Old 03-05-2014   #10
USAZR1
USAZR1's Avatar
Will a C4 shift pattern insert fit in a C5 shift knob? Anyone know where I can find a C4 shift knob in Torch Red? My upholstery shop can reupholster ours but I would rather just buy one,outright.
Clint & Sherry
1994 ZR-1 White/Red #152 (sold)
1991 ZR-1 Callaway Aerobody #1332 (sold)
1990 ZR-1 Red/Red #952 (sold)
2002 Z06 Torch Red/Mod Red widebody
