Old 02-22-2014   #1
rjb48
Default A/C underhood fuse for '90 ZR-1
Does anyone know where the underhood A/C fuse is on a '90 ZR-1? The manual says near the blower motor. My blower runs all the time even after replacing programmer and blower module.
rjb48 is offline   Reply With Quote
Old 02-23-2014   #2
Marc Haibeck
Default Re: A/C underhood fuse for '90 ZR-1
The fuse is in a little single fuse holder located under the coolant surge tank. That's the black coolant tank. Remove the two fasteners and lift the tank by flexing the hoses. The fuse holder is attached to a stud on the firewall.
Be careful not to dislodge the grommet when reinstalling the tank. If it falls into the wheelhouse it may disappear.
Old 02-25-2014   #3
rjb48
Thank you Marc...your are a life saver.
