![]() Join Date: Jan 2004
I am installing SW headers on a 90 Z and the pass side header has a 1/2 inch male quick connect air fitting welded on #2 cylinder. Whats that for ?
Also... do I need to lift the motor a little to change the oil pan gasket? If so...one side or both?
91 ZR-1 #661 Watsons, 3" exhaust, Borlas... Hurst, 4.11s, Samco, RD radiator, gel coated motor... turquise / black |
#2 | |
Lift the front of engine a bit (remove two motor mount nuts) to get those three (90') or four (93'-95') front 6mm oil pan bolts out. Some remove the cross boxes. Engine lifted in front with 2x4 wood spacer in place. ![]() Oil Pans and Gaskets Differences TIPS Installing New Oil Pan Gasket New Oil Pan Gasket and Bolts Oil pan gasket
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 02-22-2014 at 03:14 PM. |
![]() Join Date: Aug 2013
Installing on Ã* friends Z, sw headers and B&B exhaust.
Made with M10 thread on the inside and screwed in a stainless bolt. At Jerrysgaskets.com you can find a good installation guide for the oil pan gasket. Or just follow the links from Dynomite , I use them quite often too. Last edited by Jitse; 02-22-2014 at 04:33 AM. |
Thanks...
