Old 01-23-2014   #1
Default Check your spare Cam covers, Please:)
Anyone have 3337?
Old 01-23-2014   #2
Default Re: Check your spare Cam covers, Please:)
Anyone have 3337?
I have never heard of a "spare Cam Cover" as I think the Heads are Matched to each Cam Cover.......Just saying. I think it has to do with the way the Cam Journal Bearings are Machined.
Dynomite is online now   Reply With Quote
Old 01-23-2014   #3
I am asking if anyone has cover #3337 many are used as wall décor, etc...
If not, I will buy a spare and have it machined....its been done and worked....technology has come along way since 1990
Old 01-23-2014   #4
Are these "spare Cam Covers" Bearing Surfaces filled in and then re-machined (machined when installed on the Heads)?
Old 01-23-2014   #5
I have the bottom to 3337...looking for the top......no different than with a crank and choosing bearings clearance are checked and adjustments are made, that might include welding. Cam bearing surfaces are pretty forgiving if you search it....you simply need to know the tolerances...I am not reinventing the wheel, this is also done on some European exotics
Old 01-23-2014   #6
I am sure it is possible and have seen Cam Covers damaged by Timing Chains letting go but just was interested in what all has to be done and how it is done (sounds like the word "simply" might not apply)
Old 01-23-2014   #7
I do not buy into the hype of what cannot get done....
Old 01-23-2014   #8
OK
Would be a great HOW TO when you get to it
Thanks Lee........
Old 01-23-2014   #9
Just to Circle back, if you have a cam cover hanging on your wall, and its 3337, let me know
longshot but something to do in the winter
Thanks
Old 01-23-2014   #10
BigJohn
BigJohn's Avatar
I have two that have never been Machined!!!
