Old 09-23-2006   #1
tenedios
Default 15 year old tire sensors are the Achilles Heal of the Beast
I am a new member and own a 1991 ZR1. I just want to convey to you folks a "safety" concern. I was travelling close to where life begins and suddenly the car vibrated to either side of the road. It shook sideways violently. I thought I blew a tire. I managed to coast down and pull to the side of the road. No flat tires but I could not even proceed home at speeds greater than 55 without the car vibrating. At very low speeds I heard a clanking sound and thought it was the brake calipers.I wondered if I lost a wheel weight and was out of balance. My mechanic pulled the tires and the left front sensor and right rear sensor had cracked apart from the metal banding which held the sensors in place. The plastic housing were apart and the electronic circuit boards were freely floating in the tire. It seems that the 15 year old plastic sensor could not take the high angular velocity. I pulled out all the sensors. A lesson learned.
tenedios is offline   Reply With Quote
Old 09-24-2006   #2
Jeffvette
Default Re: 15 year old tire sensors are the Achilles Heal of the Beast
Yep, they are garbage. I've known a few people that have lost them on the dyno, and it is violent.
Old 09-24-2006   #3
Ccmano
Yup...pulled mine because of the same concern. Light doesn't even come on now
Hans
Old 09-24-2006   #4
tccrab
tccrab's Avatar
Boy, oh Boy. Must have been quite a pucker moment.
Glad to hear that you *and* your ZR1 survived the incident.
How are your nerves, still shaking?
TomC
'90ZR1 #792
Old 09-24-2006   #5
tenedios
Well yes. It is a classic story. My wife and I were driving to a local restaurant and she said " the road is straight for several miles and I do not see any cars ahead". So I did what any male would do when presented the situation. However she was very frightened and I am sure that will be the last time she makes suggestions like that.
Old 09-25-2006   #6
Glad nothing bad happened to the both of you! That must have been an eye opener.
Does anyone know for sure on the early cars, I have a 90, what to do with the dash lights for the system? Do we pull the sensors and pull the two bulbs from the DIC? Is the "software" to run the system in the PROM? Can that be re-flashed to eliminate it?
Old 09-25-2006   #7
Peaven
Peaven's Avatar
Glad to hear that you're safe....and thanks for giving the final nudge I needed to yank mine off soon, probably next week.
Peaven is offline   Reply With Quote
Old 09-25-2006   #8
Z Factor
Z Factor's Avatar
Hello and welcome to the forum.
If you take them off, but hold onto them incase you sell some day and the new owner wants them.
Old 09-25-2006   #9
Aurora40
Aurora40's Avatar
No need to pull the bulbs on a '90. We are lucky. I've no sensors (well they are in my basement) and no light. I'm fairly certain the light comes on during the ignition-on check.
Old 10-04-2006   #10
Jim Jones
Jim Jones's Avatar
Location: I'm in a constant state of euphoria in the Z!
I have had my light come on a couple of times, both times it was when I had low tire pressure. If the sensors aren't on the wheel, won't the light stay on?
Mine is a 1990 as well.
Jim Jones is offline   Reply With Quote
