01-20-2014 | #1 |
Battery Tenders
I was looking on Amazon for a Battery Tender and there are some very mixed reviews. Many not so flattering. Also one review noted that you should buy a Battery Tender to accommodate the type of battery you have, like a gel battery etc. I have used them in the past with good results. What's the story?
01-20-2014 | #2 | |
Re: Battery Tenders
http://zr1.net/forum/showthread.php?...Battery+Tender
Robert J. DeMarco [SIGPIC][/SIGPIC] [COLOR=blue]G[/COLOR][COLOR=red]rand[/COLOR] [COLOR=blue]S[/COLOR][COLOR=red]port[/COLOR] Registry Lifetime Member NCM Lifetime Member #2655 Pacecar Registry Member [COLOR=red]ZOOM Charter Member - ZR-1 Owners of Michigan[/COLOR] [COLOR=plum][I]ZR-1[/I] Registry member since 2012 [/COLOR] [COLOR=black]1990 LPE "368" Aerobody ZR-1, Last ZR-1 built by John[/COLOR] 1991 Callaway Aerobody ZR-1, DRM 500 1991 Shinoda Aerobody Spyder, 1998 Pace Car |
01-20-2014 | #3 |
Re: Battery Tenders
Hi,
I bought a charger from CTEK, a MXS 5.0. It restored my flat battery and has kept it charged this winter. Ken |
01-20-2014 | #4 | |
Re: Battery Tenders
Self-discharge is what all batteries do when just sitting and not connected to anything. What a tender should do is provide a compensating current for self-discharge AND a slight amount to compensate for keeping the car electronics alive. If the tender provides 1 amp or so you run the risk of damage. Some tenders monitor voltage and kick in and off depending on the reading. My float charger provides a constant 200ma. That amount does a great job on preventing self-discharge and a bit more for the car. A disconnected battery will still slowly discharge itself. This amount will be slowed if the temperature is cold. But a frozen battery is bad news all the way around. Just in case someone does not get my point: I would not pick a tender whose current is sustained above 1amp. A disconnected battery will self-discharge over time.
01-20-2014 | #5 | |
Re: Battery Tenders
I've used various versions of the BTs for 12 years w/o a single problem. My favorite is the little waterproof 800mA unit. Never had a problem with automotive lead-acid batteries; one battery on one of the 800mA tenders is in its 8 or 9th year and still cranks an 11:1 compression 350 cid SBC like it did when it was new. I give the Battery Tender a THUMBS UP!
01-20-2014 | #6 | |
Re: Battery Tenders
01-20-2014 | #7 |
Re: Battery Tenders
Scott, ya beat me toit. But, once again we're in agreement. (and don't think I'm not worried!!!)
01-20-2014 | #8 |
Re: Battery Tenders
Been running a battery tender plus for 6 years, they work well
01-20-2014 | #9 | |
Re: Battery Tenders
I just have too many batteries.......so what I do is just disconnect the negative or positive terminals (negative on ZR1s). I usually let most of the equipments sit for 5 months and when I reconnect they ALL fire right up. Just saying....... I have been doing this for .......oh...I should NOT say this.....OK......more than 6 years Not to worry Paul |
01-20-2014 | #10 | |
Re: Battery Tenders
