Old 01-16-2014   #1
John Boothby
John Boothby's Avatar
Default WTB ECM 1990 ZR-1
Looks like I might need an ECM.
John Boothby is offline   Reply With Quote
Old 01-16-2014   #2
Schrade
Default Re: WTB ECM 1990 ZR-1
Why are you thinking this Mr B.?
What test confirmed that a circuit failed between ECM input, and ECM circuit output?
(same B/Day there JB - anniversary of flight!)
Old 01-16-2014   #3
Kevin
Kevin's Avatar
you can use any year zr-1 ecm in any year zr-1. I ran a 94 ecm as a test piece earlier this year. I also need an ecm
Old 01-16-2014   #4
Marc may be able to help you out John.
Old 01-16-2014   #5
John Boothby
I ran the grounding C17 pin described by Haibeck. However, I have noticed that the MAP sensor has a lot of oil in it. I also noticed that the PCV valves are real oily. I ordered a new MAP and hose from Jerry, and will see if this solves the code 61 problem. Everything under the plenum is working according to the grounding test. It is either a sensor or the ECM. I beleive I will hold off on the ECM unil I replace the PCV valves and MAP sensor and hose. I may need a catch can. I have not had this problem before, and the car does not seem to be using oil. I drive about 1200-1500 miles annually and change the oil once a year. Never have added oil. I do beleive the oil has been overfilled by the dealer, even though I have emphatically told him to only add no more than 9 quarts.
Great responces. Thanks guys!!
Old 01-16-2014   #6
Schrade
I did half a dozen closed loop cycles, idle only, just recently, after top end CLEANUP, and upon repeat plenum pull, had some NEW oil pooled at PCV-to-plenum inlet.
Marc said completely normal, even after such a short time...
Old 01-16-2014   #7
bradley
code 61 is usually a port throttle solenoid failure. I know I had this happen to my 90. the vac system will still hold vacuum ,but the port throttle prevents things from working . kind of a generic explanation .
bradley is offline   Reply With Quote
Old 01-16-2014   #8
bradley
a catch can solved that problem for me .dynamite has a good little how to if you would like to install one
Old 01-16-2014   #9
John Boothby
Yea, I know. I replaced the solenoid and I still get the 61. When I had the plenum off, I checked the actuators and vacumn holding integrity and all checked out.
Old 01-16-2014   #10
Schrade
I'm considering that Bradley - the thought of the oil pulling through the burn has little appeal.
I asked Marc, and Dom, about routing the line in front of the air filter, with the plenum inlet capped. They weren't really impressed...
I'm going to investigate further here. Good vacuum through a fabbed port is necessary.
